Clutch Issues..?
Old Nov 19, 2006 | 01:02 PM
CodyC142's Avatar
Default Clutch Issues..?
Ok well my clutch pedal had some play in it, so I replaced the clutch cyclinder, the clutch has LOTS of play, and it doesnt engage until almost the floor
Is this the slave cyclinder? I bleed the **** out of clutch cyclinder after replacing, Would like to fix this soon
This is in a 93 Si Hb. I know the clutch is obvoisuly hydrolic, Is there anyway to adjust the clutch pedal?
Thansk In Advance
-Cody
Old Nov 19, 2006 | 01:19 PM
CodyC142's Avatar
Default Re: Clutch Issues..? (CodyC142)
moving fast
Old Nov 19, 2006 | 01:40 PM
CodyC142's Avatar
Anyone?
Old Nov 19, 2006 | 02:25 PM
CodyC142's Avatar
thread moves fast
Old Nov 19, 2006 | 03:54 PM
CodyC142's Avatar
no one?
Old Nov 19, 2006 | 05:12 PM
CodyC142's Avatar
please? anyone ?
Old Nov 19, 2006 | 06:04 PM
EG2Driver's Avatar
you have air in the line or something is wrong. Did you replace the master or slave cylinder? Is anything leaking at all?
Old Nov 19, 2006 | 06:13 PM
dtownrex's Avatar
look up under the drivers floorboard and where the push rod on the clutch pedal goes into the firewall see if there is any fluid there.
if there is then you need a new master!
Old Nov 19, 2006 | 06:50 PM
.Kevin.'s Avatar
Default Re: (slammed99gsr)
I am going to say you still have air in the system. I thought I was bleeding my clutch right until i read a little more and figured out I was not. How are you bleeding the clutch?
Old Nov 20, 2006 | 08:34 AM
CodyC142's Avatar
Default Re: (Ep_Kevin)
I replaced the master cyclinder, there is no extra fluid leaking
Im bleeding it like you would a break.. pump it like a ****, hold it to the floor, then a buddy open the slave cyclinder, then close. Repeated probably 30ish times. I made sure the resvoir never got low, that way no more air got in.
Thanks for the responses.
Any more input would be greatly appreciated
Thanks Again
-Cody
Old Nov 20, 2006 | 02:00 PM
CodyC142's Avatar
Default Re: (CodyC142)
anyone?
Old Nov 20, 2006 | 02:05 PM
SwiftMertes's Avatar
I'm out of ideas, sorry!
Old Nov 20, 2006 | 02:09 PM
EX-T's Avatar
Did you prime the master cylinder with fluid?
Old Nov 20, 2006 | 03:37 PM
jdm_eg06's Avatar
Do not pump the clutch like a ****. You'll end up with a mily broth of clutch fluid and air. Pump is slowly and evenly, eventually the pedal feel will come back. If it takes a long time take a break (about 15 - 20 min) so that any air in the line can accumulate at the line hisghest point instead of being dispersed throughout the line.
Old Nov 20, 2006 | 04:45 PM
CodyC142's Avatar
Default Re: (jdm_eg06)
ok.. Ill try that tomorrow
Thanks Alot
Old Nov 20, 2006 | 09:55 PM
SlowTeg's Avatar
Flush the clutch line by pumping the clutch pedal w/ the line open. You should get alot of large air pockets out this way. Add fluid as necessary, and then close the line and bleed it like normal. This should do the trick.
-Mike
Dre_559
May 28, 2009 08:23 PM
honda305
Sep 13, 2007 02:06 AM
Paluce
Jun 8, 2007 12:52 PM
tvman
Jul 16, 2005 11:30 AM
Paste
Aug 15, 2002 08:49 PM
