b18b obd2 swap in obd0 DA question
Old Nov 19, 2006 | 12:28 PM
PROJECT 91's Avatar
Default b18b obd2 swap in obd0 DA question
im putting a obd2 ls motor in my obd0 DA. on the obd0 ls, on the back of the block, there is 3 sensors and one is the oil pressure sensor, another one is the coolant temp sensor, im not sure what the other sensor is. does anyone know? that sensor isnt on the obd2 motor. i know all the basics, just doesnt see like im getting it tho, people say everything will go.
my questions are:
what is that other sensor, its has a big rubber cover and it a two right sensor?
how would i be able to put use to the obd2 intake manifold?
if i use the obd2 manifold, how do i go about my obd0 stock map sensor, cause the map sensor on the obd2 mani. is on top?
should i just stay with my stock manifold?
obd2 intake manifolds dont have the egr valve (FITV), so how will that work with my obd0 setup?
any help would be great im working on a wire tuck also, so any info would great
Old Nov 19, 2006 | 01:49 PM
Sam92Teg's Avatar
Default Re: b18b obd2 swap in obd0 DA question (PROJECT 91)
The sensor low and to the left of the oil filter should be your oil pressure sensor that operates the in-dash warning light. The one high and to the left of the oil filter should be your oil temp switch for the condensor fan. Then the one high and to the right of the oil filter would be your engine coolant temp switch, as apposed to being on the rear of your thermostat housing like the obd1 models. Not sure where the OBD2's temp switch is.
As for the IM, I would visit G2IC.com and do a search if you don't get the answers here soon enough.
Old Nov 19, 2006 | 02:41 PM
PROJECT 91's Avatar
ive searched everywhere, no one had any good straight forward for me. ive checked here, g2ic, teamintegra, and hondaswap and still no answers. im thinking im just gonna go with my stock manifold, but i still need to no where i plug the oil temp switch. i dont see anything on the obd2.
pleej
11
Jul 6, 2010 02:31 PM
DA-VISION-763
Jul 5, 2008 03:36 PM
sneakypete
Mar 2, 2004 11:31 AM
legendboy
Jan 6, 2003 07:02 AM
