What part is this? (under map on gsr)
Like the title says. What is this called? it goes under the map on gsr manifold this is what the car is doing.. when this part is on. when i take this part off it runs fine untill i get on it real hard then it throws abunch of codes
https://honda-tech.com/zerothread?id=1808085
That would be a missing link. I'm guessing your car is/was turbo'ed.
http://www.nipponpower.com/product.phtml?p=235
Remove it, make sure all your vacuum lines are hooked up CORRECTLY, and make sure your ecu is running a stock program, or at least an N/A program. If you're still throwing map codes, then your sensor might be FUBAR.
What exactly are you doing? What ecu are you running? If your still turboed and running a FMU youll be throwing a code without that on there.
Edit: Went through your thread you posted, sounds like your map and TPS are mixed up.
That is a MAP bypass block its function is to bypass any boost pressure to reach the MAP sensor. Remove that check your vacumn lines should run fine if not i would probably switch TB's see if that will cure it
boostedcivicsir
Jul 24, 2007 11:49 AM
boostedcivicsir
Jul 24, 2007 06:17 AM
JDMKid71
20
Mar 7, 2006 01:01 PM
