Swap Help plz....
Old Nov 19, 2006 | 10:54 AM
ssdiablo's Avatar
Default Swap Help plz....
im swaping a B18b1 on a Eg and im using my Obd1 Eg wiring harness everything plugs fine... but when i try to start the car looks like No GAS ITS going to The Injectors ...... what can it be ?
Old Nov 19, 2006 | 12:10 PM
mec. pedri's Avatar
check all your fuses
also check to make sure that the 10mm bolt that holds the engine harness ground is tight (near thermostat housing)
Gumbygrom
May 13, 2018 10:28 PM
Kaleb_Johnson
Apr 15, 2014 02:07 PM
handafreak2112
Mar 25, 2013 01:40 PM
jgibbs99si
Nov 15, 2008 08:03 AM
Yak BallZ
21
Nov 21, 2006 11:08 PM
