poor man's type r coolant routing
Old Nov 19, 2006 | 10:02 AM
steronz's Avatar
Default poor man's type r coolant routing
ok, gonna take baby steps just to make sure i covered everything. head is an obd-0 b16, block is an obd-II b18c. i figure i should have 4 holes before i drop it in.. 2 for the radiator hoses, 2 for the heater hoses. right now i've got 5 (and a half).
on the head, i've got:
those i get. on the back of the block:
my block didn't come with an oil cooler, which i shrugged off because the crossover pipe on the back doesn't have a nipple for the coolant lines that usually go there. which makes things pretty simple... 1 nipple that will snake its way over to the heater, and another that goes to the IACV.
this is where i get confused:
on the head i still have 1 small nipple without a home. nearest i can tell, everything that needs coolant is getting coolant. should i just cap this off? or will i need to T it in somewhere?
also, the t-stat housing has a threaded hole on it. i didn't get anything with my short block to go into that hole. i looked it up in the acura parts catalog, and it looks like i need to get a $30 t-stat switch to plug that up. true? do i even have wiring for that? car is still obd-0.
thanks everyone.
Old Nov 19, 2006 | 03:18 PM
gsrious's Avatar
just plug the hole.
Freemananana
20
Aug 24, 2013 11:46 AM
OH_1fstgsr
14
Jul 21, 2008 06:03 PM
steronz
Nov 19, 2006 03:51 PM
1bar_ek
May 7, 2005 07:57 AM
3rdGteg
Oct 24, 2002 05:30 AM
