quick 92-95 vss ?
Old Nov 19, 2006 | 09:31 AM
D15Bbigred's Avatar
Default quick 92-95 vss ?
i have a 93 civic , with a reg dx hydro trans, last night , my speedo went completely dead then it came back after a minute, i was just driving down the freeway no slamming gears. my ? is wouldn't i get the code if its going bad? and also what vss's will work if i decide to change it out?
Old Nov 19, 2006 | 09:47 AM
kaiba's Avatar
Default Re: quick 92-95 vss ? (D15Bbigred)
Could also be a bad speedometer.
Old Nov 19, 2006 | 09:54 AM
D15Bbigred's Avatar
yah i hope thats not it. thats not even fixable.
Old Nov 19, 2006 | 10:45 AM
kaiba's Avatar
Default Re: (D15Bbigred)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D15Bbigred &raquo;</TD></TR><TR><TD CLASS="quote">yah i hope thats not it. thats not even fixable.</TD></TR></TABLE>
Sure it is. Just get another cluster and swap it.
Old Nov 19, 2006 | 10:55 AM
93CX's Avatar
Default Re: (kaiba)
Are you getting code 17 VSS?
Old Nov 19, 2006 | 10:57 AM
D15Bbigred's Avatar
nope as stated in first post, no code , which worrys me, hell i don't know how to swap the speedo part of the cluster, i can take my cluster in and out, thats easy.. but if i swap the speedo part from another cluster, don't i lose my mileage?? which in any case could easily be illegal
Old Nov 19, 2006 | 11:06 AM
kaiba's Avatar
I heard that you can take you new(used) cluster to honda and have them adjust the mileage to match you current one.
Old Nov 19, 2006 | 11:21 AM
ej1 assasin's Avatar
Default Re: (kaiba)
this is true i had it done on my 98 coupe
Old Nov 19, 2006 | 12:20 PM
D15Bbigred's Avatar
oh for serious? ok thats works, so i can take the speedo out of any gauge cluster from 92-95 civic? also i noticed today, my miles don't record either, wouldn't that sugest that the vss is broken, because if it was just the speedo and the vss was fine, woulnd't it still calculate mileage?
Old Nov 20, 2006 | 06:26 AM
D15Bbigred's Avatar
up one last time
hondaboy4life
Oct 9, 2006 09:35 AM
LudeJdm
11
Jul 2, 2005 11:40 AM
Mach69
Jun 3, 2005 06:50 PM
shonnys92si
Mar 13, 2003 06:14 PM
