speedo cable installation help!
Old Nov 19, 2006 | 07:54 AM
philkehn's Avatar
Default speedo cable installation help!
ok with my speedo cable i go to put it in the tranny half, how do i know that its properly seated in the hole????
Old Nov 19, 2006 | 08:04 AM
Under Con. CrX's Avatar
Default Re: speedo cable installation help! (philkehn)
if you can pull it out fairly easy then its not in right but if you need to tug on it then its fine and did you replace the little c-clamp??
Old Nov 19, 2006 | 09:55 AM
philkehn's Avatar
I dont know what the c clamp is haha, i bought the car and the cable was unplugged when i got it so i never messed with it, i purchased a b16 and changed it from elec vss to cable vss now i just need to know how to put it in the hole
Old Nov 19, 2006 | 10:01 AM
steronz's Avatar
you can just twist it around until you feel it drop down. there's a little C clip that holds it in that will only clip on once it's properly seated. if you didn't get the C clip, you'll have to get creative.
Old Nov 19, 2006 | 10:08 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
look here toward the bottom:
https://honda-tech.com/zerothread?id=1325930
crxblues
Dec 6, 2006 10:44 AM
Smokinsax
Jul 8, 2005 08:45 AM
jcrou
Dec 17, 2004 08:56 AM
drjondurst
Mar 29, 2003 06:34 PM
Monty
Oct 5, 2002 09:46 AM
