itr tranny with GM synchromesh fluid helps grinds?
Old Nov 18, 2006 | 09:24 PM
blinx9900's Avatar
Default itr tranny with GM synchromesh fluid helps grinds?
so has anybody tired using the GM synchromesh fluid to help reduce grinding on the itr tranny? i know the 88-91 lsd honda trannys respond really well to it and a lot of other non GM car owners use the stuff and love it!!... any opinions any body tried it?
Old Nov 19, 2006 | 08:20 AM
Comp97GSR's Avatar
Default Re: itr tranny with GM synchromesh fluid helps grinds? (blinx9900)
If you can do a search, I am sure you will find a bunch of threads with the info. you are looking for.
IMO, I feel that Synchromesh only masks problems with trannies.
Old Nov 19, 2006 | 10:14 AM
. a d a m's Avatar
Default Re: itr tranny with GM synchromesh fluid helps grinds? (Comp97GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Comp97GSR &raquo;</TD></TR><TR><TD CLASS="quote">
IMO, I feel that Synchromesh only masks problems with trannies. </TD></TR></TABLE>
Exactly what I was going to say. If you just want to ignore it for a while, then use it, but if you really want to fix it, then this isn't the way to do it.
Old Nov 19, 2006 | 10:22 AM
tartje's Avatar
Default Re: itr tranny with GM synchromesh fluid helps grinds? (. a d a m)
the problem won't be "cured" by using different fluid. it will only mask it, the problem will still be there
Old Nov 19, 2006 | 01:54 PM
blinx9900's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Comp97GSR &raquo;</TD></TR><TR><TD CLASS="quote">If you can do a search, I am sure you will find a bunch of threads with the info. you are looking for.
thats funny cause i did and only 2 came up but i just realised i was searching recent... oops...
Old Nov 19, 2006 | 01:55 PM
blinx9900's Avatar
masking is fine with me... im not going to spend 1500 on a rebuild if fluid can stop/reduce my 3rd gear grinding...
Old Nov 19, 2006 | 02:04 PM
Comp97GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 &raquo;</TD></TR><TR><TD CLASS="quote">
thats funny cause i did and only 2 came up but i just realised i was searching recent... oops...</TD></TR></TABLE>
You can try searching other forums too, try the Tech forum.
https://honda-tech.com/zerothread?id=1760586
https://honda-tech.com/zerothread?id=1241679
https://honda-tech.com/zerothread?id=742143
https://honda-tech.com/zerothread?id=620135
https://honda-tech.com/zerothread?id=578549
https://honda-tech.com/zerothread?id=582351
https://honda-tech.com/zerothread?id=449756
https://honda-tech.com/zerothread?id=326383
https://honda-tech.com/zerothread?id=216107
https://honda-tech.com/zerothread?id=280604
Old Nov 19, 2006 | 02:29 PM
blinx9900's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Comp97GSR &raquo;</TD></TR><TR><TD CLASS="quote">You can try searching other forums too, try the Tech forum.
wow bro cant you see im admitting i made a mistake and i know how to serach... go ahead rub it in more if it makes you feel your ***** is bigger...
Old Nov 19, 2006 | 02:44 PM
Comp97GSR's Avatar
wow bro cant you see im admitting i made a mistake and i know how to serach... go ahead rub it in more if it makes you feel your ***** is bigger... </TD></TR></TABLE>
I was trying to help..... what a bitch
Old Nov 19, 2006 | 02:46 PM
blinx9900's Avatar
if you where trying to help then thanks and sorry... its hard to tell sometimes...
Old Nov 19, 2006 | 04:17 PM
BrOkEn_Dc2's Avatar
Internet sucks for trying to help but seems like your being rude... and jokes can go wrong also. lol
Old Nov 19, 2006 | 04:18 PM
blinx9900's Avatar
Default Re: itr tranny with GM synchromesh fluid helps grinds? (Spoon07)
are you referring to me?
Old Nov 19, 2006 | 05:39 PM
Comp97GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 &raquo;</TD></TR><TR><TD CLASS="quote">are you referring to me?</TD></TR></TABLE>
Who cares? I already know I have a bigger p3ni$ anyway.
Old Nov 19, 2006 | 05:50 PM
blinx9900's Avatar
probably, mines is pretty small... last girl laughed at me i thought 2.5" was big atleast decent...
Old Nov 19, 2006 | 05:57 PM
Comp97GSR's Avatar
LOL damn dood
Old Nov 19, 2006 | 08:17 PM
blinx9900's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Comp97GSR &raquo;</TD></TR><TR><TD CLASS="quote">LOL damn dood </TD></TR></TABLE>
i strated hanging weights from it, i think im up to 3.5" now so you better whach out son!
Old Nov 19, 2006 | 08:23 PM
330R's Avatar
Old Nov 21, 2006 | 09:04 AM
TOO MUCH TORQUE's Avatar
there is a new HONDA MTF fluid. Go give that a try
http://tsx.acurazine.com/forum...fluid
laziebun
Aug 1, 2008 08:30 AM
ef 4dr
13
Jan 13, 2008 08:54 AM
integra123
Oct 2, 2006 10:00 PM
vtec2nv
Jun 30, 2006 07:14 AM
RacerMike
Jul 21, 2002 11:18 AM
