wiring harness question
It might be a stupid question but I have a 98 type r and was wondering if a gsr wiring harness (the one that runs under and across the dash) would work for my car. Mine is burnt up and trying to locate one seems impossible other than the dealership(expensive). All help is appreciated. Thanks
If you are referring to the dash harness, a 98 GSR dash harness should work. If you are referring to the main harness that comes across and plugs into the fuse box, not without some modification. G/L
It's the one that connects abs, airbags, ecu, guage cluster, right headlight, etc. It's like twelve feet long.
Modified by hontoyo at 7:27 PM 11/19/2006
i'm going to check the part number tomorrow on a gsr and type r harness to see if they match. I just want to make sure before I spend the money that my investment is secured. thanks for all the help. If anyone else knows any info, I appreciate your input.
PN's are different. I can tell you the differences between the 97 GSR and ITR harnessesbut I am unsure of the 98 +.
I PM'd you, I have a 98 ITR main harness that I can sell you and you can take out any guess work and repinning that may be involved.
Definitely interested in your harness. If you could pm me a price that would be great. Also want to make sure we are talking about the same harness. Thanks
Steve
Steve
It is the harness that goes from the turn signals all the way around to the dash fuse box. It is un-cut other than the turn signal plugs and horn plug were ripped off due to a front end collision.
I'm ready to buy, just let me know how you want to be paid. I will need abs, unfortunitely so many wires got burned It's hard to distinguish certain ones plus I don't want to chance them being bad. Also how do you pm on here? I can't find the function, all I can find is im.
Go into MY PROFILE, select ALLOW INSTANT MESSAGES. You should be good. We can continue this through IM so we don't **** anybody off. you got PM
