overheating
Old Nov 18, 2006 | 09:57 AM
bjrobinson72's Avatar
Default overheating
My car is over heating and i don't know what is wrong with my car. The belts are good and the fuses are good. The only thing is that the fans don't turn on and i don't think ther is nothing is wrong with the thermostat.
Old Nov 18, 2006 | 11:24 AM
Kista20's Avatar
Default Re: overheating (bjrobinson72)
if your fan is not turing on then it really sounds like it's your fan relay switch.
Old Nov 23, 2006 | 11:23 AM
'94civic b16's Avatar
I would check the thermo switch. Also if your fan hasnt been turning on then chances are good that it ruined your thermostat. Also check for air in your coolant as this is a common issue that causes overheating. Good luck
Old Nov 23, 2006 | 02:24 PM
Syndacate's Avatar
You don't think?
Change the thermostat anyways.
Old Nov 23, 2006 | 04:26 PM
old man neri's Avatar
When you drive on the highway for a long period of time, does it still over heat? Or does it only overheat idling in traffic?
crxnatic
Apr 4, 2009 05:43 PM
ryan_1014
Feb 23, 2009 06:40 AM
yangtech
Oct 6, 2005 06:44 PM
ATS*Mark
Dec 9, 2003 11:08 PM
B_1_8_hatch
Jan 23, 2003 07:03 PM
