Harmonic Balancer Puller for Crank bolt?
Old Nov 18, 2006 | 08:55 AM
BoltonGSR's Avatar
Default Harmonic Balancer Puller for Crank bolt?
I went to autozoo and told them i need to take off my crank bolt from my gsr. They gave me a harmonic balancer puller tool? Will that work?
Modified by BoltonGSR at 12:25 PM 11/18/2006
Old Nov 18, 2006 | 09:06 AM
95 integra's Avatar
Default Re: Harmonic Balancer Puller for Crank bolt? (BoltonGSR)
Im pretty sure thats more like a pulley puller, not anything thats going to help you get the bolt out. Its not the honda speciality tool that holds the pulley/crank from turning when you try to loosne it.
Old Nov 18, 2006 | 09:16 AM
Sam92Teg's Avatar
I used a tool similar to this, only $15
http://www.amazon.com/Alltrade...&s=hi
but mine was alittle different. You use a 1/2 inch breaker bar with this tool to hold the crankshaft pulley still, then use another 1/2 inch breaker bar with a socket to break the crank pulley bolt loose.
Old Nov 18, 2006 | 09:24 AM
BoltonGSR's Avatar
Default Re: Harmonic Balancer Puller for Crank bolt? (Sam92Teg)
Im guessing you screw those bolts into that metal piece into the pulley? But i just dont see it works...
Old Nov 22, 2006 | 12:47 PM
BoltonGSR's Avatar
Ok, i got the pully holder tool now. How am i supposed to hold it in place? Its got a place for a half inch drive to go, i guess i need some to hold in place while i break the bolt loose?
bradley
13
Jan 9, 2012 02:12 PM
barrera
Oct 11, 2010 07:17 AM
KCUF_DB8
Apr 2, 2010 09:18 PM
TrueZen
Feb 27, 2004 07:42 AM
yuckymucky
21
Mar 30, 2003 07:04 PM
