throwing codes in my EG
Old Nov 18, 2006 | 03:29 AM
nub_pwn's Avatar
Default throwing codes in my EG
well finally got around to it, i checked my codes....im throwing CEL 23, and 41
23 is knock sensor
41 is o2 sensor
my question is,
1)does the knock sensor go bad easily? can this be the reason why im wacking rev limiter at 7 grand? i dont hear any knocking idle is at 1000
2)if i do disable the o2 sensor will this help in performance?
i need help, im thinking of jus taking it out and overhauling it
Old Nov 18, 2006 | 10:17 AM
nub_pwn's Avatar
bumpppppppp
Old Nov 18, 2006 | 10:30 AM
nub_pwn's Avatar
bummmmppp
Old Nov 18, 2006 | 10:51 AM
Seahawk's Avatar
Default Re: throwing codes in my EG (nub_pwn)
All stock? What model?
I'll tell you that I have a 94 VX and I had a O2 CEL and was getting average 32-34 MPG. After I bought a new (expensive) 5 wire O2 sensor my gas mileage is back up to 44-47 MPG.
Old Nov 18, 2006 | 11:06 AM
nub_pwn's Avatar
oh ya sorry i have a GSR OBD1 in my hatch
Old Nov 18, 2006 | 11:41 AM
nub_pwn's Avatar
bummmmmmmmpppppppppppp
Old Nov 18, 2006 | 02:22 PM
nub_pwn's Avatar
ANYBODY?!?!!?!?!?!?! need help
Old Nov 18, 2006 | 05:40 PM
jdm_eg06's Avatar
got a gsr in my hatch too. Did you run the wire for your knock sensor to the proper pin on the ECU. if you didnt your timing will probably be extremely retarded when the revs get high (vtec) to avoid detonation. My 94 hatch had a d16z6 in it with a p28, those engines didnt have a knock sensor, therefore i had to run the wire myself when i did the swap using an obd1 p72 ecu. Once i did run the wire it really woke the car up, the code went away and she pulled a little harder.
as for the o2 sensor i also have that code, but its for the o2 sensor heater, im sure its just a wiring issue that ill look into this weekend and let you know.
Old Nov 18, 2006 | 07:48 PM
nub_pwn's Avatar
Default Re: (jdm_eg06)
yup jus came from my friends house who helped me do the swap, and he didnt wire in the knock sensor to the ECU, i have a Z6 in their to so no knock sensor on sohc's...hmm ok
Old Nov 18, 2006 | 11:53 PM
mintscorpion's Avatar
Default Re: (nub_pwn)
if you don't replace your 02 sensor your car will stay in open loop and will run very rich. you need closed loop in order for your car to run correctly.
Old Nov 19, 2006 | 02:31 PM
nub_pwn's Avatar
ok fixed the knock sensor, we manually wired it to the ECU which was pretty easy thx to ff-squad thumbs up for them, well now its only throwing code 41 which is o2, car is still revving out at 7000, we checked and theres no clip on the exhaust foir 02 guess the guys took it off with their old exhaust wen replacing it
Old Nov 19, 2006 | 02:32 PM
nub_pwn's Avatar
am i in limp mode? due to o2 sensor CEL
minituner
Mar 26, 2016 04:16 PM
category5 SI
Jan 8, 2014 04:28 PM
Crank
Sep 14, 2004 10:21 PM
UNDER PRESSURE
Aug 23, 2004 02:54 PM
1.8EG-T
Nov 5, 2001 12:08 PM
