Internal axle seperation, how do I get it back in?
Old Nov 18, 2006 | 03:10 AM
B16 IIgen's Avatar
Default Internal axle seperation, how do I get it back in?
My friend and I were in the middl eof a B16 swap. on the drivers side next on the half shaft, we were installing the new Axle. Well, when we realized that we'd put the axle on the half shaft without fitting it between the damper fork, we began to pull it back out, so it wouldn't slide out (we did use grease) and in the process of pulling it out, the tri bearings inside the axle boot seperated. We've done some extensive seraching but cannot find the solution to our problem. So, is it possible to get those SOB's back in? Or what, if som how exactly? My ownly solutino would be to twist and turn the bastard until it locks back into place, but I've never actually had this problem come up, therefore I'm at a loss.
I'd appriceate some help with this matter...thanks!
Old Nov 18, 2006 | 04:35 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
Default Re: Internal axle seperation, how do I get it back in? (DX94')
you need to remove the boot, put the assembly together, then reboot it. sorry.
Old Nov 18, 2006 | 06:10 AM
MonkeyPuzzle's Avatar
had the same problem.
I didn't need to remove the boot to get it back in. But it did take ages of working to get it back together.
Just removing the boot to fix the problem is really the easiest solution.
Old Nov 18, 2006 | 11:43 AM
Kista20's Avatar
Default Re: Internal axle seperation, how do I get it back in? (MonkeyPuzzle)
what they said just bite the bullet and pull it apart, sucks though it can be a bit of pita... good luck to ya though.
Old Nov 19, 2006 | 02:58 AM
Metalluthier's Avatar
Default Re: Internal axle seperation, how do I get it back in? (Kista20)
Yea, we finally just decided to remove the boot and insert the bearings back into the casing. Deffinately a pain in the *** and a real lesson learner! Thanks anyways guys
DJ Analog Duck (V.A. Mix) - Eastern Duck Heads West (2001) - 01 - Eastern Duck Heads West.mp3 [192Kbps] (04:12)
EGPrelude
Jun 17, 2008 07:46 AM
LS94tegra
Apr 19, 2008 11:59 AM
Endo-land
Sep 9, 2007 08:12 AM
bab33face
Oct 22, 2006 01:45 PM
huepowered
Mar 27, 2006 12:33 PM
