Which modern mount kits give the best fitment?
Here's a list of the most popular mount kits for the JDM OBD0 B16a (with S1 cable trans.) swap into an 88-91 EF:
-Arizona Race & Machine
-HCP
-Hasport
-Innovative Mounts
-Enjo
I may not have listed them all, but which kit should fit the best?
Also, I noticed that Innovative has a set of swap axles for their mounts. Is this to say that a manufacturer has a recommended set of axles for use with their mount kit? For example, is their a recommended set of axles that should be used with Hasport mounts? etc?
I currently have my mind set on the Arizona mounts along with their recommended shift linkage. Is this a bad move? If not, what axle kit should I go with for proper fitment?????
-HCP
-Hasport
-Innovative Mounts
-Enjo
no you dont have to use their axles with those kits. they are pretty much just the JDM ef axles that you cant buy in the USA. so they make them so you dont have to buy integra axles.
IDriveHonda
79
Dec 4, 2003 02:32 PM
Charlie Moua
Apr 10, 2002 04:02 PM
