225 BF Drag radials..
Old Nov 18, 2006 | 12:11 AM
jitterbox2's Avatar
Default 225 BF Drag radials..
To all of the guys running the 225 br Drag radials... I wanted to run 205/50R15's in the summer but if I can get 225's under there then that would be even better!
What is the size of your tires/rims? What Rims are you using?
What is your camber at?
I have a camber kit that fits my 205/40R17's perfectly ( can not remeber the camber value....) Will the 225's fit? (Sorry if it is a silly question...)
Thanks
Derek
Old Nov 18, 2006 | 07:52 AM
drumking15's Avatar
im running stocker fat 5's...work awesome...and hook like a motha...also im at stock height and they rub a lil at full tilt...
Old Nov 18, 2006 | 08:49 AM
chasemyhonda's Avatar
B A N N E D
Ive wanted to put some 225's on my car. i doubt they would fit on a 6" or 6.5" wide rim
Old Nov 18, 2006 | 09:44 AM
livinlow's Avatar
Default Re: (komat)
15"x7" rota gt3 with the 225/50/15 bfg fits, but I had to jack the front of the car up a little to make sure everything cleared. I also have the inside of my front fenders trimmed a little as well. I also run 205/40/17 regularly with even tire to fender gap to give you an idea of how low it is. I raised up the front probably 1/2" to 3/4" of an inch to not be scared about driving it on the street.
Old Nov 18, 2006 | 10:50 AM
miyagi's Avatar
Default Re: (livinlow)
95 GSR, no camber kit, eibach prokit
225/50/15 BFG radials on 15x6.5 rota attacks.
Rubbed the inner fender on lock to lock turns, and rubbed a bit on hard bumps ... other than that it wasn't bad at all.
A friend of mine had them on his 97 DX coupe on 15x7 rota gt3's, omnipower camber kit, lowered enough so there was no fender gap at all on ground control coilovers ... rubbed a bit more than mine, but nothing crazy.
Old Nov 18, 2006 | 11:28 AM
qfast817's Avatar
Default Re: (miyagi)
had 225 on my gsr blades, they griped way better than the 205 i have now
Old Nov 18, 2006 | 12:18 PM
drumking15's Avatar
Default Re: (blindingxenon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blindingxenon &raquo;</TD></TR><TR><TD CLASS="quote">Ive wanted to put some 225's on my car. i doubt they would fit on a 6" or 6.5" wide rim</TD></TR></TABLE>
i doubt the 6" but def a 6.5" rim...i have on em my stockers :-p nice thick sidewall too...just gotta watch out for curbs...
Old Nov 18, 2006 | 02:27 PM
Tchleung's Avatar
I run 225/45/17 on my 17" wheels. 7.5" wide wheel. lowered 1". Rubs badly anymroe then 80% turn. Hooks good tho. Have run 12.02's in a 2650 lbs weight Integra.
Old Nov 18, 2006 | 02:56 PM
BlueSi2k's Avatar
Default Re: (Tchleung)
I use 225s on stock si wheels for the track. Lowered about 1.25 they rub a little at full lock and sometimes over a big bump. Grip awesome though.
Old Nov 18, 2006 | 04:08 PM
0554's Avatar
Default Re: 225 BF Drag radials.. (jitterbox2)
i run 225/50/15 on stock itr wheels. cut a few 1.7 sixty foots with them and consitant low 1.8's. but yea they only run when fully locked
95egHatchSi
Oct 17, 2013 06:50 PM
jdmchickx
Jan 5, 2012 03:12 PM
siblues
May 22, 2007 10:42 AM
JFG Kevin
Dec 29, 2003 07:59 AM
ruiner17
Apr 3, 2002 11:00 PM
