Tire sizing HELP!!
well...i got some gsr blades rite now...my car is dropped with some h&r sport...1.75 in the front and 1.5 in the bak....i want to go with some bigger rims but i'm afraid it would rub on the fender lining....I'm wondering if i put some 205.50.15 on my blades..would it rub...and what size tires should i go fo with i'm using 16's and 17's....i am usin a camber kit on the front tires...but there is a lil negative set on it...
first off what size tires are you running on your rims right now, 205.50.15? keep in mind that a 15" rim with a 50 tire could almost be the same as a 16" with a 40. less metal more tire vs. more metal less tire. my buddy is running the same setup as you. 205.50.15 with the same drop and he doesnt rub, just dont take any corner rank fast cause it might rub. well that what my dad and i were talking about the other night and came to this conclusion. oh yeah and the 15 is more likely to be lighter!!
rite now...i have stock sizin on the blades which are 195.55.15...my tires still rub when i do a U turn...but it doesn't rub if i take a corner real hard...i'm just wondering would it be worst to have one 205.50.15....
Since you're already rubbing with the stock size tires, then don't get tires that are wider (e.g. 205) or have a larger outer diameter.
In fact, since you're already rubbing with the stock size tires, you might want to consider getting rid of some of that drop...
Drewsgotshoes
Feb 18, 2017 08:30 PM
Honissan
Oct 4, 2004 01:57 PM
