stretching tires
im going to buy ssr mesh wheels for my dc2. the wheels are 4x100 15x7 with 10 off-set and im wondering since its 15x7 will i be able to stretch falken ziex or falken azenis tires ?
For an Integra with 15" wheels, you should get tires that are 195/55-15 or 205/50-15. Both sizes are approved for mounting on rim widths as high as 15x7, so you could mount those tires on 15x7. But you're better off getting 15x6.
However, I don't understand why anyone in Southern California would get Ziex all-season tires, unless you drive your car to places where it snows...
Modified by nsxtasy at 8:20 AM 11/18/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by waddy41 »</TD></TR><TR><TD CLASS="quote">195-45
i'd do it if i had an eg...smaller wheel well/smaller car</TD></TR></TABLE>
195-45s would be stretched like ****... VW style
[ WOW, that will stick out a lot and probably rub. Why such high offset?[/QUOTE]
you mean why such a low offset old man neri
he probably like some people like that look...you are not going to be really stretching those tires on that wheel width...i have run 15x7 with a 205-50r15 with a 35mm offset and looks good and does the job just fine... that offset thou will make it a little bit harder for you to run a 195/55r15 without rubbing on the inside of you fender... you will probably have to run a 195/45r15 or a 195/50r15 to make it work which is not a recommended fitment for your car
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by old man neri »</TD></TR><TR><TD CLASS="quote">A 10 offset rim? WOW, that will stick out a lot and probably rub. Why such high offset?</TD></TR></TABLE>
so it turns better.
besides i dont need to worry about running spacers and it looks real hard on a dc2.
IMO
rolled my fenders.
i got 33 off-set right now, still not enough.
so it turns better.
IMOrolled my fenders.
would you have problems if you get a tire size that won't be stretched for you wheels.
wheels with stretched tires look so ugly and you aren't even using the width the wheels were designed for.
it just looks funny.
variable
Aug 7, 2010 12:59 PM
