rings sealed, good compression...still smoking sometimes.
Old Nov 17, 2006 | 02:14 PM
stevil_knevil's Avatar
Default rings sealed, good compression...still smoking sometimes.
i have a b18 ls swap in my 98 ek hatch. broke car in nice and good. checked compression a few times over the past couple of months, and still burning oil(about a quart every 2-4 weeks), and when I add the necessary quart, or change the oil, it'll smoke screen for a lil' while after i drive it some. had a 3-angle valve job, and new valve seals put in when i had my head p&p'd and resurfaced. could i be looking at a leaking valve(s), or head problem somewhere? talked to a few shops, and tuner folks, and was told it's probably either the rings didn't seal up(but holding even compression on all cylinders), or that it's acting like they didn't lap the valves back in when they replaced the seals and did the 3-angle, and that that will cause it to blow air up through the valves, and let oil leak down to the combustion chamber. does that sound feasable to anyone. plus, i have to reset and retighten my valves about once a month. never had that problem before with any other honda. can anyone give me any insight to this. it's gotten really old, and is really embarrassing when it smokes like it does...it's BAD! if anyone can help, please do. Thanks!
Old Nov 17, 2006 | 02:18 PM
93egsir's Avatar
Default Re: rings sealed, good compression...still smoking sometimes. (stevil_knevil)
you said you did a compression check.
I would start with a leak down test to see where the oil is coming from that is being dumped in the exhaust.
Old Nov 17, 2006 | 02:22 PM
JDM-EJ698's Avatar
Default Re: rings sealed, good compression...still smoking sometimes. (93egsir)
bump.have the same problem on my ls/vtec?
Old Nov 17, 2006 | 04:41 PM
Default Re: rings sealed, good compression...still smoking sometimes. (JDM-EJ698)
oh yeah, also, i'm running je 9.0:1 pistons w/Nippon Gas Nitride coated rings, made for boost/nitrous applications, and i've been running na for a couple months. Just got my turbo kit completed, and going on this weekend(hopefully). read a thread on here or evans tuning about someone having rings made for a turbo app., and said they had a lil' more end gap to allow for more expansion from the heat of a turbo'd engine. make sense to anyone? that a possibility? but still showing even compression on all 4's?
Old Nov 17, 2006 | 05:54 PM
anyone with this problem before?? know answer?? going to do leak down test tomorrow.
CRX-CHACE
Jul 1, 2013 05:55 PM
t00JDM
Oct 21, 2010 12:48 PM
hornetd23
Nov 11, 2008 05:51 PM
chickenandpickles
Aug 30, 2005 11:21 PM
Digital-R
Feb 19, 2002 08:52 PM
