no p/s, how do i plug off the rack??
Old Nov 17, 2006 | 10:45 AM
boostedbigguy's Avatar
Default no p/s, how do i plug off the rack??
i have a 94 ex coupe but i dont have power steering, is there some type of way to plug off the rack so i dont lose fluids? a friend of mine told me some one found it here but im not sure where to look.
Old Nov 17, 2006 | 04:06 PM
89s1's Avatar
Default Re: no p/s, how do i plug off the rack?? (boostedbigguy)
run the in and out lines on the rack in a loop.
Old Nov 18, 2006 | 11:01 AM
blacksi93's Avatar
Default Re: no p/s, how do i plug off the rack?? (89s1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89s1 &raquo;</TD></TR><TR><TD CLASS="quote">run the in and out lines on the rack in a loop.</TD></TR></TABLE>
yes because you dont want to plug them at all
Old Nov 18, 2006 | 12:26 PM
clayne's Avatar
Default Re: no p/s, how do i plug off the rack?? (blacksi93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blacksi93 &raquo;</TD></TR><TR><TD CLASS="quote">
yes because you dont want to plug them at all</TD></TR></TABLE>
That's not really true. Using a minimal amount of fluid as left over lubrication and plugging the input/outputs does not cause a serious issue. Done it on the FD, and done it on the EG. No issue.
One small exception I will add is that I did not use completely airtight NPT or 3/8" plugs, I capped them off.
Old Nov 18, 2006 | 04:18 PM
0554's Avatar
correct way to do it is to loop the in and out.
Old Nov 18, 2006 | 07:56 PM
thelate1's Avatar
Default Re: (0554)
also, make sure to remove all the fluid(that is still under pressure). i made sure to turn my steering wheel back and forth numerous times. if not, the steering will feel extremely tight.
Old Nov 18, 2006 | 08:17 PM
clayne's Avatar
Default Re: (thelate1)
Yep. That's why I say it's not too essential to loop the lines as there shouldn't be so much fluid in there that the loop is actually being used - but that's just my method.
Old Nov 18, 2006 | 08:31 PM
MidwestSiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thelate1 &raquo;</TD></TR><TR><TD CLASS="quote">also, make sure to remove all the fluid(that is still under pressure). i made sure to turn my steering wheel back and forth numerous times. if not, the steering will feel extremely tight.</TD></TR></TABLE>
yeah.. me and a friend plugged his rack with a little more fluid than we wanted in there and the rack was very tight
Old Nov 20, 2006 | 01:47 PM
Default Re: (0554)
kool thanx now i can finish that part of my project, word up
Old Nov 24, 2006 | 05:22 AM
89s1's Avatar
Default Re: (0554)
Thanks for the back-up 0554
Old Nov 27, 2006 | 07:55 AM
does anyone happen to have a pic of this set up, because im kinda confused, on the rack there is 3 lines comming out of it, theres the one that goes to the pump on the block then theres 2 other ones that ran to the cooler on the front of the car, which ones get looped, and what do i do with the other line, just plug it?
Old Nov 28, 2006 | 05:09 AM
Mr HYDE's Avatar
bump for pictures of the setup
Old Nov 29, 2006 | 01:47 PM
Default Re: no p/s, how do i plug off the rack?? (Mr. HYDE)
bump again
Old Dec 6, 2006 | 01:54 PM
bump!
jdmcivicracer89
Aug 2, 2007 03:32 PM
prelude_93vtec
May 10, 2007 10:48 AM
invisible
18
Mar 26, 2007 09:08 PM
Joey.
Apr 20, 2006 03:41 PM
allmotorEG-SI
Sep 19, 2003 12:56 PM
