h22a tranny problem
I happen to be driving to work and while in the action of shifting to 4th gear the tranny whould not go. It was in nuetral as if something was wrong with the clutch or flywheel. The pedal does feel different, but I just installed a new clutch and flywheel about 3000 miles ago. Just need help.
I have checked the fluid level and everything, I guess I need to call my sister to help me bleed the clutch master cylinder. Then I guess I'll check the slave jont.
I have had same problem and found out it was the slave cylender also if you have performance clutch somtimes worn seals will not hold the extra pressure of the pressure plate. Also check the rubber hose coming off the master sometimes there is a leak or pinhole that allowes air into the system
Just some suggestions
Drizzo
13
Aug 5, 2004 08:44 AM
