no spark from dizzy
From: I told you to wait in the truck in Texas, United States
How about the ignitor?
I have had two fail on me...
Also make sure the distributor is actually turning..
if not the timing belt is broke..
ok dude it might be the ignitor but theres no way in hell its my timing belt it was replaced a couple weeks ago and since then the car has not moved. so im buying a new dizzy and i hope there is no main relay that can cause the dizzy not to work.
the timing belt was not broken when i replaced it u r supposed to replace it, and the water pump before u do a swap. because u dont know for a fact how many miles the motor has on it. Im not some dumb as boob that dosent no my $hit i only ask questions to get a second opinion
yeah i think thats the prob because i replaced all my grounds and sanded the conections and know my ecu is showing power before that i had no power from dizzy or ecu i will buy a new dizzy the ignitor must be bad. Ill give it a shot thanks man someone on Honda tech with some since
d4ng3rb0y
15
Nov 24, 2009 08:15 AM
Jack Shephard
12
Feb 13, 2009 06:27 PM
