gt4294r------coolant lines?
Old Nov 17, 2006 | 07:48 AM
mec. pedri's Avatar
Default gt4294r------coolant lines?
Just got my gt4294r and was wondering if the coolant lines are an absolute must. I've seen a couple pics of some SFWD car on here that dont run them. The car will not see much street time.
pics would also be appreciated......thanks.
Old Nov 17, 2006 | 07:51 AM
tommyten's Avatar
Default Re: gt4294r------coolant lines? (mec. pedri)
if its ball bearing then you should probably run coolant lines
Old Nov 17, 2006 | 07:58 AM
DaveF's Avatar
Default Re: gt4294r------coolant lines? (tommyten)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tommyten &raquo;</TD></TR><TR><TD CLASS="quote">if its ball bearing then you should probably run coolant lines</TD></TR></TABLE>
we havent run them ever.
Old Nov 17, 2006 | 07:59 AM
tommyten's Avatar
precision & ATP sell water line kits for those turbos...they come with most of the parts you need.
Modified by tommyten at 11:28 AM 11/18/2006
Old Nov 17, 2006 | 08:00 AM
underpressure02's Avatar
I was told not to run them on my GT40.
Old Nov 17, 2006 | 08:09 AM
eddie_ek's Avatar
Default Re: gt4294r------coolant lines? (underpressure02)
Why not run the lines, is it bad I ran it on my PT-67R
Old Nov 17, 2006 | 08:10 AM
Default Re: gt4294r------coolant lines? (eddie_ek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eddie_ek &raquo;</TD></TR><TR><TD CLASS="quote">Why not run the lines, is it bad I ran it on my PT-67R</TD></TR></TABLE>
I heard that the seals sometimes leak and the water will cause it to rust.
Old Nov 17, 2006 | 08:22 AM
HybridKOOP's Avatar
I'd run them. BB turbo CHRA's use barely ANY oil... only enough to lube the bearings. Without the water being ran, the turbo is seeing virtually no cooling effect from the oil.
A journal bearing turbo runs so much oil through the CHRA, that it keeps it cool as well.
Old Nov 17, 2006 | 08:33 AM
eddie_ek's Avatar
Default Re: gt4294r------coolant lines? (HybridKOOP)
My turbo has a restrictor on the oil feed so it only gets a little oil
Old Nov 17, 2006 | 08:42 AM
GarrettGTBB's Avatar
Banned
We absolutely recommend it - protect your investment from coking!
Old Nov 17, 2006 | 09:33 AM
wolve's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GarrettGTBB &raquo;</TD></TR><TR><TD CLASS="quote">We absolutely recommend it - protect your investment from coking!</TD></TR></TABLE>
end of discussion
Old Nov 17, 2006 | 09:44 AM
SpeedDreamz.com's Avatar
Default Re: gt4294r------coolant lines? (GarrettGTBB)
even on a drag only car?
Old Nov 17, 2006 | 10:07 AM
FMUNK's Avatar
Default Re: gt4294r------coolant lines? (SpeedDreamz.com)
We do not run them on our car.........but our car does not run for more than a minute or two.
SFWD cars drive too and from the lanes and go through hell compared to ours.
I recommend using cooling lines.
The BIGGEST reason is it will void your warranty on the turbo, TRUST ME, THEY CAN TELL WHEN THEY PULL YOUR TURBO APART!
The reason, I BELIEVE is because the seal in tha BB cartridge is a material like Phenolic or something like that, so without water cooling the situation heat will eventually get the best of the seal. That is something I heard Harry explain to someone, but I was not directly in the conversation. Just overheard.
Hope that helps.
Old Nov 17, 2006 | 12:38 PM
servion's Avatar
Has anyone ever personally had seen a problem with them leaking?
Old Nov 17, 2006 | 12:55 PM
mec. pedri's Avatar
Thanks Jeromie!
Looks like I'll be ordering some lines and fittings then.
Old Nov 17, 2006 | 01:15 PM
PHDZINE's Avatar
Default Re: (mec. pedri)
According to Justin @ Innovatuve turbo, he said it wasn't necessary if it's just a drag car. We run the T72 BB with no coolant lines but I highly recommend using coolant otherwise.
grand champ
Feb 25, 2008 09:20 PM
187Chor
Jan 16, 2008 05:58 PM
EKB18BPR3
Mar 28, 2006 05:03 AM
turbo*s2k
Dec 14, 2005 08:37 AM
ATS*Mark
Sep 28, 2005 09:48 AM
