code 15 car just died please help.....
Old Nov 16, 2006 | 06:38 PM
DOHCarp's Avatar
Default code 15 car just died please help.....
I was driving in heavy rain and all of a sudden my car cut out, I had no throttle. and the check engine light came on.
I was then able to start it again and drive for about a mile when it hapend again. but this time it wouldnt start back up. I plugged in my laptop and found code 15. Ignition Output Signal missing or defective ignition output signal what could be causing this???
I am not getting any fuel or spark, and I also checked all the fuses under hood and dash.
any ideas.
this is in an 96 EK converted to obd1 with hondata s300
thanks
Craig
Old Nov 17, 2006 | 02:47 PM
DOHCarp's Avatar
Default Re: code 15 car just died please help..... (DOHCarp)
anyone??
Old Nov 17, 2006 | 02:51 PM
chasemyhonda's Avatar
B A N N E D
Sounds like you need a new Ignition control module or a new distributor.
Old Nov 17, 2006 | 07:20 PM
DOHCarp's Avatar
Default Re: (blindingxenon)
I was thinking the same thing. but would the bad igniter in the distributer cause the injectors not to spray too? as I said Im not getting fuel or spark, but my fuel pump is turning on.
Old Nov 20, 2006 | 07:44 PM
igotthaspirit's Avatar
Default Re: (DOHCarp)
yea, probably the ignitor
ketchup214
Apr 17, 2010 03:03 PM
SHO-NUFF
Jan 11, 2010 10:05 AM
dump3deg6
Jul 20, 2009 09:43 PM
atm3535
Oct 4, 2006 06:13 PM
skooba steve
Jun 28, 2006 01:07 PM
