hydro locked?
Old Nov 16, 2006 | 01:05 PM
BlueLude 94's Avatar
Default hydro locked?
Before anyone tries to bash the story goes like this. I was heading to class today and i came across this puddle. I thought about making a u turn and taking a longer wa to class but then a cop pulled up behind me. So i took my chances and went through the puddle. As soon as my front two wheels went it it rolled for about 3 feet then shut off and kept rolling. I tried to get it started again outside of the puddle and it wont even try to urn over.
So is my motor done or what could the problem be?
Old Nov 16, 2006 | 01:28 PM
preludedriva's Avatar
same thing happened to me but my car made it through :D
anyways do you have a cold air intake? were you pressing on the gas while going through the puddle? is your car lowered? and how big was the puddle?
does the car give any hesitation in starting? try pushing on the gas and the clutch pedal when starting it might be able to burn some of the water outa the motor , thats what i did and it worked.
motors can handle a little bit of water cause it evaporates
Old Nov 16, 2006 | 01:30 PM
alterdcreations's Avatar
Default Re: (preludedriva)
take out your spark plugs and air filter and crank the engine over untill all of the water is out. replace parts and avoid puddles
Chuckles99SH's Avatar
Default Re: hydro locked? (BlueLude 94)
First off, do you have a CAI? Was the filter wet? Disconnect the CAI from the intake and see if you can determine if any water got up to the intake manifold. If you see that it is wet, dont try and start it again. pull your spark plugs and turn the motor over and see if any water comes out of your spark plug holes. If it does let it dry, do an oil change and pray to the honda gods that you didnt bend a rod or blow your head gasket.
Old Nov 16, 2006 | 01:32 PM
Default Re: hydro locked? (Chuckles99SH)
bend a rod? damn how does it bend a rod?
Old Nov 16, 2006 | 01:34 PM
Yeah I have a CAI and the car is lowered. Ill try taking out the spark plugs and see if that works. i hope i didnt bend a rod or blow the head gasket cz i was hoping to sell it soon.
Old Nov 16, 2006 | 01:39 PM
Turbo Lude SH's Avatar
Default Re: hydro locked? (preludedriva)
Water doesnt compress like air does. And it is stronger than your engine. It will break something when it gets in. Rod, Piston, head gasket, maybe all.
Old Nov 16, 2006 | 05:58 PM
Revi's Avatar
Default Re: hydro locked? (Turbo Lude SH)
Look on the bright side, thats how i ended up with a Type-S motor.
Old Nov 16, 2006 | 06:31 PM
CGags13's Avatar
..thats how i almost ended up building mine...thank god...expletive cai's...thats why bpi rocks tha party party...oh and btw dont let a cop make u do something you dont want to do..**** on 'em bo'!!
ps...when you crank the engine..squirt some oil in the plug holes...make sure you keep them spark plugs away..or disconnect the injectors..fuel will be spraying out of the plug holes...spark + fuel + a rookie I know = toasted h22 swapped ek coupe
Old Nov 16, 2006 | 08:20 PM
Default Re: (CGags13)
This isnt on the bright side for me cuz my plan was to actualy sell it and buy either a supra, s2k or a wrx depending on what i like more
Old Nov 16, 2006 | 08:37 PM
CGags13's Avatar
dont worry supras are overrated dyno queens...wrx's are subarus need i say more...and s2ks are cool..but id rather rock a nice lude at this point in my life
Old Nov 16, 2006 | 11:04 PM
SPRLude's Avatar
that sucks.. good luck with this one..let us know how it goes
Old Nov 17, 2006 | 05:38 AM
SlowBB4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CGags13 &raquo;</TD></TR><TR><TD CLASS="quote">dont worry supras are overrated dyno queens...wrx's are subarus need i say more...and s2ks are cool..but id rather rock a nice lude at this point in my life</TD></TR></TABLE>
your a d bag all three of those cars are badass. dont be a hater bc your to poor and prolly dont work hard enough to get either of the tree
Old Nov 17, 2006 | 07:51 AM
Revi's Avatar
Default Re: (SlowBB4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlowBB4 &raquo;</TD></TR><TR><TD CLASS="quote">
your a d bag all three of those cars are badass. dont be a hater bc your to poor and prolly dont work hard enough to get either of the tree </TD></TR></TABLE>
Old Nov 17, 2006 | 01:17 PM
bet you dont even have either one of those so that means your poor to eh? and that you dont work too hard cause your still rollin a prelude and not either one of the 3 other cars?
nrst89
45
Dec 20, 2008 10:35 PM
Madrek
22
Jul 20, 2005 05:38 PM
i3luedi2agon
Nov 19, 2004 07:39 PM
geminis2k
Jan 31, 2004 05:52 PM
brads94accord
May 18, 2003 05:45 PM
