D15B1 vs D15B2
Old Nov 16, 2006 | 12:27 PM
PACT man's Avatar
Default D15B1 vs D15B2
What makes the DX motor have 23 more hp than the STD motor seeing that they are both DPFI with the same displacment/bore/stroke? Is it the cam profile?
Old Nov 16, 2006 | 12:48 PM
TeamRedline89Hatch's Avatar
Default Re: D15B1 vs D15B2 (PACT man)
cam and ecu, the 5 speed helps too ive done the swap, very easy, and a nice upgrade.
Old Nov 16, 2006 | 01:34 PM
ProjectDarkBlack's Avatar
Default Re: D15B1 vs D15B2 (TeamRedline89Hatch)
B1 is an 8 valve, B2 is a 16 valve also
Old Nov 16, 2006 | 01:42 PM
Default Re: D15B1 vs D15B2 (ProjectDarkBlack)
b1 is a 16 valve motor, trust me...its in my garage if you want pics
Old Nov 16, 2006 | 01:43 PM
PACT man's Avatar
No, just looked now, says 16 valve right on the valve cover, only 8 valve D-series is 92-95 CX, same hp but not valves or manifold of injector setup...
Good to know about the cam and ECU because I already have an Si ECU for a MPFI swap now that I know I can look into getting a a6 or ZC cam also for more power, and eventually a 5 spd Si tranny which helps out more than the DX tranny, although I will put the DX 5th gear in I think.
Old Nov 16, 2006 | 02:32 PM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PACT man &raquo;</TD></TR><TR><TD CLASS="quote">only 8 valve D-series is 92-95 CX, same hp but not valves or manifold of injector setup...
88-91 CRX HF is also 8 valve engine
Old Nov 16, 2006 | 02:37 PM
PACT man's Avatar
Default Re: D15B1 vs D15B2 (jlicrx)
Yea I was wrong, don't know or deal with HF's though, what is the engine code on a HF anyways? I know 85-87 CRX Si had 12 valves... says so on the manifolds...lol
Old Nov 16, 2006 | 02:42 PM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PACT man &raquo;</TD></TR><TR><TD CLASS="quote">what is the engine code on a HF anyways?</TD></TR></TABLE>
D15B6
Old Jan 9, 2007 | 05:05 AM
Hondaisok's Avatar
If I swap out the ecu from my b2 to my b1, will I get more power?
Old Jan 9, 2007 | 06:07 AM
Tippyman's Avatar
Default Re: D15B1 vs D15B2 (Hondaisok)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondaisok &raquo;</TD></TR><TR><TD CLASS="quote">If I swap out the ecu from my b2 to my b1, will I get more power?</TD></TR></TABLE>
Usually I would say no, because you don't have the hardware to back it up. But who knows, it may give you a little. You could probably find a B2 cam for dirt cheap and then you'd see a little difference.
Old Jan 9, 2007 | 11:02 AM
extensioncordy's Avatar
i got a few si's cams. and even a stage 3 exospeed cam. all forsale. PM me if you want info
Old Jan 9, 2007 | 12:13 PM
Bense's Avatar
weird, i never knew anything about the d15b1.
Old Jan 9, 2007 | 12:35 PM
Tippyman's Avatar
Default Re: (Bense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense &raquo;</TD></TR><TR><TD CLASS="quote">weird, i never knew anything about the d15b1. </TD></TR></TABLE>
Comes in the Civic Std.'s.
They suck sooo bad.
Old Feb 7, 2007 | 03:32 PM
mchb's Avatar
Default Re: (Tippyman)
I own a d15b1 ed6 from Canada. I have 4 speed manual transmission is it the same box on your cars ?
It's very rare here in France.
Old Feb 7, 2007 | 04:00 PM
dr_latino999's Avatar
Default Re: (mchb)
I'd assume you the CDM 4-Speed to the be the same one in the states.
Old Feb 8, 2007 | 07:27 AM
mchb's Avatar
Default Re: (dr_latino999)
Ok, thank you for your answer. In France we only have 5 speed or auto tranny. I think that I will swap a 5 speed box.
Old Feb 8, 2007 | 08:20 AM
Hondaisok's Avatar
But the 5 speed vs 4 speed doesn't increase horse power. I've read all the replies, but still don't know what the difference is that increases the HP. I have both engines, the b2 is not in my hatchback, the b1 is. 20 HP seems like a lot more, has to be something different in the mechanics, I can't see that a diff ECU would make that much difference.
Old Feb 8, 2007 | 09:44 AM
driveahonda's Avatar
Cam is difference.
Ecu is different.
Exhaust manifold is different.
Intake manifold "restrictor plate" is different.
There are probably a few other things as well.
rharris84
Sep 11, 2007 12:38 PM
SVOboy
Jun 24, 2006 02:37 PM
SlAmMeD 91 HaTcH
May 16, 2005 07:01 PM
95gsr
Apr 8, 2003 07:20 AM
TDRacing
Jun 25, 2002 10:38 PM
