D15B1 vs D15B2
D15B1 vs D15B2
What makes the DX motor have 23 more hp than the STD motor seeing that they are both DPFI with the same displacment/bore/stroke? Is it the cam profile?
Re: D15B1 vs D15B2 (ProjectDarkBlack)
No, just looked now, says 16 valve right on the valve cover, only 8 valve D-series is 92-95 CX, same hp but not valves or manifold of injector setup...
Good to know about the cam and ECU because I already have an Si ECU for a MPFI swap now that I know I can look into getting a a6 or ZC cam also for more power, and eventually a 5 spd Si tranny which helps out more than the DX tranny, although I will put the DX 5th gear in I think.
Re: D15B1 vs D15B2 (PACT man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PACT man »</TD></TR><TR><TD CLASS="quote">only 8 valve D-series is 92-95 CX, same hp but not valves or manifold of injector setup...
88-91 CRX HF is also 8 valve engine
Re: D15B1 vs D15B2 (jlicrx)
Yea I was wrong, don't know or deal with HF's though, what is the engine code on a HF anyways? I know 85-87 CRX Si had 12 valves... says so on the manifolds...lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PACT man »</TD></TR><TR><TD CLASS="quote">what is the engine code on a HF anyways?</TD></TR></TABLE>
D15B6
D15B6
Re: D15B1 vs D15B2 (Hondaisok)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondaisok »</TD></TR><TR><TD CLASS="quote">If I swap out the ecu from my b2 to my b1, will I get more power?</TD></TR></TABLE>
Usually I would say no, because you don't have the hardware to back it up. But who knows, it may give you a little. You could probably find a B2 cam for dirt cheap and then you'd see a little difference.
Re: (Bense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense »</TD></TR><TR><TD CLASS="quote">weird, i never knew anything about the d15b1. </TD></TR></TABLE>
Comes in the Civic Std.'s.
They suck sooo bad.
They suck sooo bad.
Re: D15B1 vs D15B2 (TeamRedline89Hatch)
But the 5 speed vs 4 speed doesn't increase horse power. I've read all the replies, but still don't know what the difference is that increases the HP. I have both engines, the b2 is not in my hatchback, the b1 is. 20 HP seems like a lot more, has to be something different in the mechanics, I can't see that a diff ECU would make that much difference.
Cam is difference.
Ecu is different.
Exhaust manifold is different.
Intake manifold "restrictor plate" is different.
There are probably a few other things as well.
Ecu is different.
SlAmMeD 91 HaTcH
05-16-2005 07:01 PM
TDRacing
06-25-2002 10:38 PM
