where to tap in a boost gauge??
Old Nov 16, 2006 | 12:00 PM
jrs2ksi's Avatar
Default where to tap in a boost gauge??
I am installing a turbo on a 2000 honda civic si b16. I was wondering where to tap in the line to get the most accurate reading. Its a manual guage. Any pictures would help too.
thankx.
Old Nov 16, 2006 | 12:04 PM
95jeremie's Avatar
Default Re: where to tap in a boost gauge?? (jrs2ksi)
pick up a vacuum manifold and run all you vacuum sources off of it. fast turbo was selling them on here a wile back for like 30 bucks i think. tap into your break booster line and you are good to go.
Old Nov 16, 2006 | 12:06 PM
95jeremie's Avatar
Old Nov 16, 2006 | 12:21 PM
nebulight's Avatar
Default Re: where to tap in a boost gauge?? (95jeremie)
I don't buy into the vacuum manifold idea. It's nice if you don't have an aftermarket intake manifold with a lot of outputs, but I have a Victor X, and there are more than enough fittings so you don't need to use a vacuum manifold. I just T-ed off from my FPR to go to the gauge.
jrs2ksi's Avatar
wheres the break booster line?
Old Nov 16, 2006 | 12:34 PM
93turbo16's Avatar
It goes to the brake booster, by your master cylinder.
It isn't a good idea to "T" off your FPR line. Try to keep that un cut as much as possible.
Old Nov 16, 2006 | 12:38 PM
jrs2ksi's Avatar
Default Re: (93turbo16)
oh**brake booster not break booster. ok
Old Nov 16, 2006 | 01:09 PM
nebulight's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 &raquo;</TD></TR><TR><TD CLASS="quote">It goes to the brake booster, by your master cylinder.
It isn't a good idea to "T" off your FPR line. Try to keep that un cut as much as possible.</TD></TR></TABLE>
Well, when you use a vacuum manifold, you are basically doing the same thing.
Old Nov 16, 2006 | 01:14 PM
aaronISthrowed's Avatar
Default Re: (nebulight)
I would just recomend getting a fast turbo vacuum manifold, i have one and thats where i tapped my boost gauge.
Old Nov 16, 2006 | 01:21 PM
EJ1 wilcox's Avatar
Default Re: (aaronISthrowed)
Mines tapped into my fpr vacuum line. I've always had it tapped from there without any problems.
Old Nov 16, 2006 | 02:03 PM
93turbo16's Avatar
You won't really have any problems with it being tapped from the FPR. I guess I am over doing it a little bit. If it blows off anywhere on the manifold you are pretty much screwed. I just don't like it being on a vital part of my fuel system.
Old Nov 16, 2006 | 06:02 PM
dizzyek's Avatar
just T it off the fpr
done
Old Nov 16, 2006 | 09:10 PM
Sprockets's Avatar
You have cruise control. Just put the T on that vac line close to the manifold.
Old Nov 16, 2006 | 10:16 PM
Frozen E's Avatar
H-T White Ops
Default Re: where to tap in a boost gauge?? (Sprockets)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sprockets &raquo;</TD></TR><TR><TD CLASS="quote">You have cruise control. Just put the T on that vac line close to the manifold.</TD></TR></TABLE>
Damn, I was looking for that reply and didn't see it until you came along. That was going to be my $.02 to add to this.
EastCoastRust
Aug 11, 2014 11:06 AM
99delsol
Sep 20, 2006 06:57 PM
djnikko
Jan 10, 2004 11:48 AM
ClubSiRacer
Nov 12, 2003 05:10 AM
Nextelbuddy
Aug 26, 2003 10:37 AM
