HID Retrofit (need pics)
hey guys, can you guys post some pictures up of your rsx's with retrofit HID's. im looking to buy a retrofit kit and want to see what the end product looks like on a rsx. thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NTCustoms »</TD></TR><TR><TD CLASS="quote">by retrofit do you mean putting in OEM D2S HID's into your stock housing or are you talking about just the plug and play kits that use H1 bulbs</TD></TR></TABLE>
yes taking the OEM D2S HID's into the stock housing, not the plug and play, i want the real deal. plug and play are horrible i had it once, to much glare
not to burst your bubble, but HID's in any stock housing that aren't projectors will result in glare. also, since D2S are MADE for projectors, you will have bad light output, because the focal point for these dont match with the housing. if you want to use D2S bulbs, you should do a retrofit with projectors to maximize the correct use of D2S bulbs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NTCustoms »</TD></TR><TR><TD CLASS="quote">not to burst your bubble, but HID's in any stock housing that aren't projectors will result in glare. also, since D2S are MADE for projectors, you will have bad light output, because the focal point for these dont match with the housing. if you want to use D2S bulbs, you should do a retrofit with projectors to maximize the correct use of D2S bulbs</TD></TR></TABLE>
yess that is what i ment by retrofit, i want to put projectors into my housing..... anybody have pics?
