Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
No oil in motor!
Old Nov 16, 2006 | 09:42 AM
Kevm30's Avatar
Default No oil in motor!
Wel i guess i musta screw something up. I changed my oil on my ex about 4 months ago, my first oil change. I just changed it again, when i took out the drain plug, only about 1 quart came out. I kno i put in 1 gallon, and i tighted the drain plug tight and the oil filters tight. Nothin was leakin and i never noticed any oil spots on the ground. IDK what happened. Anyways do you think there could be any engine damage? The car ran and sounded fine. I just dont know if i need to do anything?
Old Nov 16, 2006 | 09:50 AM
Type X's Avatar
Default Re: No oil in motor! (Kevm30)
did you check under by the bolt for drips
theres NO POSSIBLE WAY that it leaked out 3/4 of the oil and you didnt see a spot on your driveway in 4 months.
Old Nov 16, 2006 | 11:36 AM
Otherguy's Avatar
NASIOC.com
Default Re: No oil in motor! (Type X)
hmmm... interesting, has your car been burning oil?
Old Nov 16, 2006 | 12:44 PM
NBPcivic07's Avatar
Default Re: No oil in motor! (Otherguy)
that sounds scary
Old Nov 16, 2006 | 01:03 PM
Kevm30's Avatar
Im prety sure a brand new car isnt goin to burn 3 quarts of oil in 4 months, i just wana kno do you think theres any engine damage. I was using sythentic oil.
Old Nov 16, 2006 | 01:10 PM
TRAG's Avatar
did you replace the o-ring under the bolt? a used or damaged o-ring could cause a leak. Oil shouldnt burn n e ways...it should just get dirty. oil doesnt just "dissapear" something is fishy??
Old Nov 16, 2006 | 01:30 PM
Kevm30's Avatar
Are u sure theres a oring under the bolt? I didnt notice any
Old Nov 16, 2006 | 01:33 PM
Tadehi's Avatar
Schumacher '10 WDC
Default Re: (Kevm30)
This may sound a$$ like but, did you lift the car properly? Not trying to be an a$$ or anything. Could be that not all you oil poured out, as if you car was on an angle or something.
Old Nov 16, 2006 | 01:49 PM
TRAG's Avatar
im pretty sure there was a "circle shaped metal piece" up under my bolt that i got a couple extra of just because i have always heard to replace it with every oil change. or maybe im just hearing things. i dunno though, just my .02 cents
Old Nov 16, 2006 | 04:33 PM
COMplex.'s Avatar
Default Re: (TRAG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TRAG &raquo;</TD></TR><TR><TD CLASS="quote">im pretty sure there was a "circle shaped metal piece" up under my bolt that i got a couple extra of just because i have always heard to replace it with every oil change. or maybe im just hearing things. i dunno though, just my .02 cents</TD></TR></TABLE>
It's a crush washer and yes, it's good to replace with each oil change.
Old Nov 16, 2006 | 05:12 PM
B16B_coupe's Avatar
HRD PKR
Default Re: (j.fuggi)
yes listen to the guy above.. always replace. the crush ring.. we do at every service at honda
Old Nov 16, 2006 | 07:22 PM
eL's Avatar
eL
Reusing a crusher ring ONCE isn't going to lead to a loss of 3 or 4 quarts.
Old Nov 16, 2006 | 08:04 PM
Kevm30's Avatar
Isnt there sopposed to be a oil warning light that sould come on when theres a lack of oil pressure?
Old Nov 16, 2006 | 08:30 PM
eL's Avatar
eL
You said you were missing 3qts of oil. There were no oil spots under your car? Did you check under the car [on the engine somewhere] if there was a leak? If you're missing that much oil... it's on the ground somewhere or your engine burned it and there would be tons of smoke. Just inspect it, fill it back up, then check frequently.
Old Nov 17, 2006 | 09:55 AM
TRAG's Avatar
if the crush ring was in fact damaged, or there was no crush ring at all...the oil could slowly leak out over time...or the bolt may not have been tightened all the way, you are supposed to torque it to a certain amount so you dont have it to tight or to loose...therefore causing a 3 qt oil loss. it could slowly be dripping as he drives or something. 3 months is a reasonable amount of time where oil loss could happen.
but i also agree with you. maybe the car wasnt lifted right...but it must have been if hes able to put a gallon in their.
There is just something that is not right.
Old Nov 17, 2006 | 11:22 AM
Kevm30's Avatar
Car was on flat surface, i used the jack to jack to jack it up and get under it. I tried lowering it back on level ground to get more oil out. Only 1 qt came out. There was never any leaks under the car. I just wana know it you think there can be any motor dammage?
Old Nov 17, 2006 | 11:54 AM
MonkeyConQueso's Avatar
Take it into the dealership or another mechanic and get an engine diagnostic. We can't tell you if there is any damage to the engine, and I'm sure all of us can postulate all day on if there is or isn't.
EGgoJDM
Dec 1, 2009 12:05 PM
DO_ITR_YoungD_19
Honda S2000
11
Nov 24, 2008 08:38 PM
tilhasbb
17
Aug 13, 2007 08:17 AM
97akwerd
Aug 8, 2005 01:46 PM
CRXstress
Sep 27, 2004 10:01 PM
