gt35 non-ball bearing on a 2.3 liter... opinions wanted.
Old Nov 16, 2006 | 05:32 AM
twkdCD595's Avatar
Default gt35 non-ball bearing on a 2.3 liter... opinions wanted.
whats the opinions here on these units? anyone wanna take a stab at spooling this on a 9.0:1 compression motor?
precision gt35
.63 t3 exhaust side
.70 compressor side
Old Nov 16, 2006 | 05:49 AM
slow poke's Avatar
Default Re: gt35 non-ball bearing on a 2.3 liter... opinions wanted. (twkdCD595)
Soulds like a good setup too me. What are your power goals?
Old Nov 16, 2006 | 06:23 AM
PrecisionH23a's Avatar
I would say about 4250-4750rpms if you are running a ball bearing.
Old Nov 16, 2006 | 07:54 AM
b18sihatch's Avatar
Default Re: gt35 non-ball bearing on a 2.3 liter... opinions wanted. (PrecisionH23a)
dont believe he is looking to go ball bearing, but its a good choice if he was
Old Nov 16, 2006 | 08:08 AM
tuned_vtec
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">I would say about 4250-4750rpms if you are running a ball bearing.</TD></TR></TABLE>
That doesn't leave much left for a power band, thats only about 1/3 of his rpm range. If that thing starts to get moving at 4250-4750rpms your going to hate it.
Old Nov 16, 2006 | 08:18 AM
Default Re: gt35 non-ball bearing on a 2.3 liter... opinions wanted. (tuned_vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tuned_vtec &raquo;</TD></TR><TR><TD CLASS="quote">
That doesn't leave much left for a power band, thats only about 1/3 of his rpm range. If that thing starts to get moving at 4250-4750rpms your going to hate it.</TD></TR></TABLE>
I ran a t4 sc61 (.70, .58a/r) that was spooled around 4750-5000 on my build 2.4 h23a1. Even though I only revved to around 7500, the power band was fine for me.
Old Nov 16, 2006 | 08:35 AM
tuned_vtec
Guest
Posts: n/a
I ran a t4 sc61 (.70, .58a/r) that was spooled around 4750-5000 on my build 2.4 h23a1. Even though I only revved to around 7500, the power band was fine for me.</TD></TR></TABLE>
Ok, and the car probably feels pretty much stock before that. In normal driving, I'd say, shifting a 4000 or so, it will be frustrating to not have any power on tap. Your going to have to downshift all of the time and it's going to be annoying. Its not going to be fun to drive. This is the problem I have now with a big t3/t04e, and I'm going to smash it into little pieces when I get a new GT turbo.
Old Nov 16, 2006 | 08:43 AM
b18sihatch's Avatar
im in the same kinda situation when it comes to turbos,
i have a fulley built block
sleeved
je 8:1 compression pistons
crower h beam rods
the whole 9 yards
thing is with my setup and low compression ratio i dont want the turbo to spool real late in the rpm and i wanted it somewhat early in the rpm and only want to rev to factory rev limit.
a smaller gt-r series turbo is probably what i will go with, given the fact i may run 15-20psi daily its hard to say where my motor will spool in the rpm
same thing with 9:1 compression pistons, you want something somewhat fast in the rpm to spool and want it as early as possible for full boost. the larger you go the later the spool try to find a happy medium
Old Nov 16, 2006 | 08:45 AM
Suprdave's Avatar
Default Re: gt35 non-ball bearing on a 2.3 liter... opinions wanted. (b18sihatch)
Chad,
Both of those Turbos have 61mm Wheels...I would use a SC61 P-Trim .63AR.
Either in T3 or T4. T3 would be SC6176, T4 is PT61
Use that displacement
When's the new project going to be ready to throw down?
BOMBCRU
Aug 1, 2008 01:19 PM
cueballsi
Feb 18, 2005 06:21 PM
Benjithx
Feb 4, 2005 12:03 PM
built4cubanlynxx
Sep 9, 2004 04:52 PM
SRT-WHORE
Dec 9, 2003 07:15 PM
