removing air conditioning....
Old Nov 15, 2006 | 09:09 PM
B16 IIgen's Avatar
Default removing air conditioning....
does anyone know how to remove the air conditioning unit on a 94' civic, i heard its pressureized but i dont know for sure...... any specifics or pictures would be awesome!!!!
Old Nov 15, 2006 | 09:18 PM
GoonieAsian's Avatar
Default Re: removing air conditioning.... (DX94')
it is pressurized so loosen the bolt that is running from the a metal hose to the a/c condensor which next to the radiator and step back and watch the fun
Old Nov 15, 2006 | 10:12 PM
Jhonny Ricer's Avatar
Default Re: removing air conditioning.... (GoonieAsian)
soo bad for the environment bring it to a shop and have them drain it for you
Old Nov 15, 2006 | 10:15 PM
alacard's Avatar
Default Re: removing air conditioning.... (Jhonny Ricer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jhonny Ricer &raquo;</TD></TR><TR><TD CLASS="quote">soo bad for the environment bring it to a shop and have them drain it for you
what he said^^
our environment is already fcuked up enough.
Old Nov 16, 2006 | 02:38 AM
Frozen E's Avatar
H-T White Ops
134A has an ozone depletion potential of ZERO.
Old Nov 16, 2006 | 02:42 AM
Boosted B6teen's Avatar
Default Re: removing air conditioning.... (IslandSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IslandSi &raquo;</TD></TR><TR><TD CLASS="quote">
134A has an ozone depletion potential of ZERO.</TD></TR></TABLE>
What he said....
Old Nov 20, 2006 | 04:31 PM
h8ted ek's Avatar
Default Re: removing air conditioning.... (Boosted B6teen)
CFC destroyin the atmosphere, dont deplete the ozone!
Old Nov 20, 2006 | 05:18 PM
suspendedHatch's Avatar
Default Re: removing air conditioning.... (h8ted ek)
Not to mention that it can make you blind.
Old Nov 20, 2006 | 05:23 PM
FastAzzCivic's Avatar
Default Re: removing air conditioning.... (suspendedHatch)
i would just take it to a shop and have the remove the ac for you.
takes like 5 mins. if that.
Old Nov 20, 2006 | 05:26 PM
Interlinker's Avatar
Default Re: removing air conditioning.... (FastAzzCivic)
Yeah and it won't kill our ozone. 134A or not... don't spill that stuff into the air. Most places will e-vac that stuff for you for a nominal fee.
Old Nov 20, 2006 | 06:48 PM
stock_honda_coupe's Avatar
Default Re: removing air conditioning.... (Interlinker)
If you get caught just venting it into the air you'll be paying over 10,000 in fines. Just take it to a shop, mabey make get a deal for leting them keep the refrigerant or some thing. After that its just removing parts.
Old Nov 20, 2006 | 06:50 PM
JDMFantasy2k's Avatar
Default Re: removing air conditioning.... (stock_honda_coupe)
take it somewhere and tell them to vac it, if they want to charge you then go home and pull the hose. It's r134, not r12, so it won't harm the environment like r12 used to, just be careful.
Old Nov 20, 2006 | 07:27 PM
Pavlo's Avatar
It is actually just as bad, they though it is not back in 1994, but it was rpoven otherwise. Have it properly dispose, and because shops reuse it, they probably won't charge anything, or very little money.
Old Nov 20, 2006 | 08:09 PM
Frozen E's Avatar
H-T White Ops
Default Re: (Pavlo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pavlo &raquo;</TD></TR><TR><TD CLASS="quote">It is actually just as bad, they though it is not back in 1994, but it was rpoven otherwise. </TD></TR></TABLE>
Show me this proof. The chemical makeup of 134A makes it have a ZERO ozone depletion potential. 134A contains ZERO chlorine (the chemical that eats away the ozone layer).
Old Jan 13, 2007 | 08:29 AM
dirkj's Avatar
Default Re: (IslandSi)
It does not deplet the ozone, but it does lead to global warming. According to your chlorine argument, CO2 should not contribute to global warming, but it is a major contributor to greenhouse gasses. See http://arch.rivm.nl/env/int/ip...2.pdf
or
http://www.mfe.govt.nz/issues/....html
Quote from above:
CO2 has been suggested as an alternative to R134a in air-conditioning systems because the global warming potential of R134a is 1300 times that of CO2. This was particularly important for automotive air-conditioning because of the relatively high leakage rates in such systems.
Old Jan 13, 2007 | 09:25 AM
billyinse's Avatar
Default Re: removing air conditioning.... (B16 IIgen)
id just let it go into the air whats a little gas when there are millions of cars in the us giving off gasses evey day .. cuz i live in sc and they dont inspect anything here
Old Jan 13, 2007 | 11:02 AM
gezzuzz's Avatar
expletive global warming. expletive the democrats.
scrcrw
24
Aug 24, 2007 08:09 PM
huge230
Nov 29, 2005 05:43 PM
Andrew240z
31
Nov 18, 2005 04:36 AM
integlspwr2k
May 28, 2005 02:54 AM
lmiguelvv
Dec 25, 2004 05:05 AM
