Methanol Injection good or bad for turbo b16
Old Nov 15, 2006 | 07:40 PM
Themouse's Avatar
Default Methanol Injection good or bad for turbo b16
I just turboed my 00 Si with the Greddy Kit and wanted to know if it would be smart to run methanol in order to up the boost by a pound or two just to get alittle more HP any opinions welcome thanx guys
Old Nov 15, 2006 | 07:46 PM
Wideopentuning's Avatar
Default Re: Methanol Injection good or bad for turbo b16 (Themouse)
Its smart no matter what, It would allow you to run some more boost as long as you have the headroom in your fuel system.
Old Nov 15, 2006 | 08:36 PM
a1320addict's Avatar
Default Re: Methanol Injection good or bad for turbo b16 (Wideopentuning)
What kind of numbers are you putting down? More details on the setup?
It's not a bad idea, but your goal of a little more power could probably be acheived much easier than a methanol system.
Old Nov 16, 2006 | 09:45 AM
Themouse's Avatar
Default Re: Methanol Injection good or bad for turbo b16 (a1320addict)
I got the car street tuned with the greddy kit on my stock b16 and i just wanted to know if it would be safe to run a methanol kit and up the boost by 2 pounds because i'm running 8psi right now on a P06 chipped with crome
thanx guys
Old Nov 16, 2006 | 10:37 AM
Just get retuned at 10 psi on pump, no need to go to methanol.
Old Nov 16, 2006 | 10:44 AM
Here is a good forum if you want to do a little research on water/methanol injection.
http://www.srtforums.com/forum...f=189
Old Nov 16, 2006 | 10:45 AM
bigbadboy's Avatar
add the methanol and get it retuned on 10. you won't believe the difference between the 2.
Old Nov 16, 2006 | 11:08 AM
Default Re: (bigbadboy)
Exactly. Check the results this S4 had in this thread near the bottom. https://honda-tech.com/zerothread?id=1804210
9ine
Mar 4, 2009 06:04 AM
RedValve
25
Sep 7, 2008 05:28 PM
ohstufffff
Nov 29, 2007 02:14 AM
crackerjacker006
May 6, 2005 06:15 AM
blacksi00
May 27, 2003 11:11 PM
