boost?
Old Nov 28, 2007 | 09:58 PM
ohstufffff's Avatar
Default boost?
yeah so im kinda a noob when it comes to boost i have a b16 ek and i was originally going to go n/a but i dont think its worth it.
1. how many psi could i run on stock internals without the threat of major damage?
2. what are some decent turbo kits that are relatively inexpensive?
3. what kind of bhp numbers would i be looking at ?
Old Nov 28, 2007 | 10:36 PM
hellakapps's Avatar
Default Re: boost? (ohshiiittt)
check the compression, make sure it's good across the board, i wouldn't run more than 10 psi on a b16 if you want to be really safe. as for turbo kits go can always go with a greddy, but the kit is hard to build off of if you want to expand your setup, due to the size of the turbo, the manifold, and the intercooler. the best way to go is piece a kit together, but that gets expensive, you can also go with a drag kit. just look into it. the's a ton of ways to do it it all depends on your budget. as for numbers you should be around 250 to 300 whp, # one thing is get it tuned, a lot of setups don't last because they are not tuned, GET IT TUNED
Old Nov 29, 2007 | 02:14 AM
boostedcivicsir's Avatar
Mr. Badwrench
welcome to the forum.
there is a wealth of knowlege here. please take the time to look for your answers first and go from there. if you still come up empty, them post up.
this is one of the stickies at the top of this forum
forced induction FAQ's:
https://honda-tech.com/zerothread/1024174
Themouse
Nov 16, 2006 11:08 AM
ViruSi
Jun 14, 2005 02:46 PM
crackerjacker006
May 6, 2005 06:15 AM
Denny
Sep 9, 2003 07:47 AM
JDMPARTS4U
May 5, 2002 02:59 PM
