Can somebody post a pic of the passenger side engine mount above the transmission
Old May 8, 2002 | 06:25 AM
JD_B18CDX's Avatar
Default Can somebody post a pic of the passenger side engine mount above the transmission
This is for a 92-95 civic hatchback with a GSR engine.
Need to verify position of mointing bracket on the body.
Also, want to know if the mount mentioned above is the same for auto and manual trans.
Thanks.
Old May 8, 2002 | 07:45 AM
ekhatchhybrid's Avatar
Default Re: Can somebody post a pic of the passenger side engine mount above the transmission (johnd)
i heard that you have to cut the auto bracket and weld a manuel bracket to the frame if you have an eg
but if you have an ek there is no cutting and welding but someone please correct me if im wrong
Old May 12, 2002 | 10:47 PM
S9 MECHA KARUMA's Avatar
Default Re: Can somebody post a pic of the passenger side engine mount above the transmission (ekhatchhybrid
EKhatchhybrid is correct, the mount on the frame rail is in a different postion from auto to manual.
Old May 12, 2002 | 10:55 PM
V8KILLA's Avatar
It is only necessary to change the mounts accordind to the engine being swapped. No cutting or welding needed.
scooterpies
Apr 13, 2017 04:03 PM
EFbattleSedan
Jun 30, 2013 06:07 AM
Jason913
29
Dec 27, 2011 07:48 AM
blackfoot
Aug 28, 2007 08:29 AM
