Ls Vtec problems
Old Nov 15, 2006 | 11:47 AM
Holderb20's Avatar
Default Ls Vtec problems
I need to know what all I need for a ls vtec I have the b16 head a oil tap kit and a vtec controler What all will in need?
Old Nov 15, 2006 | 11:52 AM
klungemonger's Avatar
You could search, this is probably the most covered Honda Hybrid subject on the internet. At any rate you out to strengthen the bottom end of an LS block for high-rpm use. ARP rod bolts, VTEC oil and water pumps would be minimum, but a crank girdle wouldn't hurt either.
Old Nov 15, 2006 | 01:36 PM
Holderb20's Avatar
Default Re: (klungemonger)
I have looked but I cant find what all I need the only thing I have are the stud bolts I know about the oil and water but I can use gsr parts for that
Old Nov 15, 2006 | 08:12 PM
Yeah GSR oil/water pumps are good, I'll be using those for the B20 I'm putting together right now. But like I was saying, fix the weakest link which is the rod bolts, and using a GSR/ITR block girdle (requires also the oil pan & pickup) will probably suffice.
DC2fab
Jan 16, 2010 01:37 PM
hondaguyexsi
Oct 12, 2005 05:19 PM
D-meet07
Sep 14, 2005 02:56 AM
mymeatb18"
Jun 4, 2005 11:24 AM
