swaping in a ls/vtec setup
Old Nov 15, 2006 | 08:16 AM
crxmex's Avatar
Default swaping in a ls/vtec setup
ok i am swaping my ls/vtec setup into my gf 4dr ls. other than ecu and distributor what else is needed? will her stock injectors work for the ls/vtec? and will the alternator plug up to the obd1 harness? the ls/vtec is in my obd0 crx. thanks for the info guys and yes i've searched but only came across vague responses in other posts.
Old Nov 15, 2006 | 08:29 AM
DC2 Mang's Avatar
Default Re: swaping in a ls/vtec setup (crxmex)
the injectors will be fine for daily driving
and the alternator from the obd0 car will plug up to the obd1 or obd2 harness i believe
Old Nov 15, 2006 | 08:43 AM
lVlemphizStylez's Avatar
Default Re: swaping in a ls/vtec setup (DC2 Mang)
eh i was pretty sure the obd2 and obd1 harnesses differed with the alternator and distributor...In fact I KNOW the dizzy plugs differ because I had to lay down some custom wiring on mine
Old Nov 15, 2006 | 09:43 AM
crxmex's Avatar
thanks alot for the forementioned info guys, so the injectors will be fine, and the obd0 alternator will plug into the obd1 harness... what about dizzy's will the ls dizzy work or do i actually need one from a obd1 dohc vtec.?
Old Nov 15, 2006 | 10:04 AM
Default Re: (crxmex)
you should get the vtec dizzy to make things easier
Old Nov 15, 2006 | 10:26 AM
DC2 Mang's Avatar
yes the distributor plugs are all different
as for the alternator, I took one off of my car (obd1 integra) and put in on my friends 90 integra which was obd0 and it plugged in, so im quite sure that those are interchangeable but im not sure about obd2
Old Nov 15, 2006 | 11:46 AM
crxmex's Avatar
thanks for the info guys this answered the questions i had regarding the swap.
Old Nov 15, 2006 | 07:18 PM
crxmex's Avatar
will the car run on a obd1 ls ecu for time being the car has to be swaped this weekend
Lee_eg6si
Welding / Fabrication
Nov 3, 2007 10:29 AM
andysrex
Feb 26, 2006 06:44 PM
Hybrid EG Hatch
Feb 6, 2006 06:10 PM
ernald711
Mar 30, 2005 08:24 PM
tremor86
Sep 1, 2003 05:23 AM
