recaros out of an EK in my EJ2
Old Nov 15, 2006 | 06:34 AM
TehMan's Avatar
Default recaros out of an EK in my EJ2
the brackets/siders that are on the seats don't bolt up in my 95 coupe...what do i need to get them to fit in?
Old Nov 15, 2006 | 06:54 AM
...Baker's Avatar
i'm guessing that the inside rear brackets are too long and all the others line up? If so.. you can just cut that one bracket arm short and drill a new hole into it
Old Nov 15, 2006 | 07:02 AM
TehMan's Avatar
Default Re: (.:Baker:.)
if i bolt the front ones up the back's sit off to the side...like they are unaligned
Old Nov 15, 2006 | 07:09 AM
...Baker's Avatar
ok, here's whatcha do:
1.) line up a front hole, put the bolt in (like 2-3 turns so it's loose)
2.) line up the rear hole that's closest to the door put the bolt in (the same as before.. loose)
3.) now go back to the front and wiggle the seat a little and it'll line up with the other hole. Put that bolt in as well.. the same way again.
4.) now see how much you need to cut off the rear inner bracket and mark where a hole is needed.
5.) take the seats out and drill/cut the one bracket as needed.
6.) put the seats back in the same way i just told you and they should bolt on in.
OR.. you can make this 100x easier and just buy eg brackets.
Old Nov 15, 2006 | 07:10 AM
sirsmokesalot's Avatar
swap the rails with your old seats
Old Nov 15, 2006 | 07:14 AM
TehMan's Avatar
will the ones off my stock seats bolt on to these?
Old Nov 15, 2006 | 07:19 AM
Default Re: (TehMan)
is it an OEM recaro seat, or is it an aftermarket recaro with ek rails?
Old Nov 15, 2006 | 07:24 AM
TehMan's Avatar
Default Re: (SirSmokesAlot)
well it's like the jdm ones that come in the type-r but its the red one not the black one
Old Nov 15, 2006 | 08:14 AM
TehMan's Avatar
well what brackets should i use? like where can i buy some? i can't get the stock ones to work
Old Nov 15, 2006 | 09:25 AM
BlueIntegraBoy's Avatar
You will need DC2/DB8 Recaro rails, but JHP has Vision rails that will work.
http://www.jhpusa.com/catalog/...d=955
Old Nov 15, 2006 | 09:35 AM
TehMan's Avatar
Default Re: (BlueIntegraBoy)
thanks
Old Nov 15, 2006 | 10:22 AM
vtec4lyfe's Avatar
"what do i need to get them to fit in?"
drill
drill bits
various bolts
hacksaw/sawsall
it may take some time but its definetly do-able
Samuels
Feb 22, 2009 07:43 PM
tunerkid7
Honda Civic (2001 - 2005)
Feb 29, 2008 06:48 AM
die_lawn
Nov 27, 2007 08:59 PM
JKov240
Feb 10, 2007 11:42 AM
Hyjnx
Oct 29, 2002 08:32 AM
