Strange sound when turning?!
Hello everyone,
I have a strange noise emitting from my front wheel wheel (I think driver's side). Whenever I make a turn, while driving slowly (5-10km/h), it makes a strange sound that sounds like 'rattling tin cans'. I thought it was my dust/splash shield, so I pushed it back, but to no avail. The sound is still there.
Can anyone please advise other causes for this?
Thanks in advance.
DAN
Thanks in advance.
DAN
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
my guess would be axle. is it only when turning that one direction?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rodney »</TD></TR><TR><TD CLASS="quote">my guess would be axle. is it only when turning that one direction?</TD></TR></TABLE>
It happens when I'm turning left or right. For example when I am turning into a parking spot at a mall, or turning into my drive way. The 'tin can' sound starts up. I don't know the severity of this, I just don't want the wheel to fly off while I'm driving.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .:Baker:. »</TD></TR><TR><TD CLASS="quote">could be the dust shield for the rotor. Try bending it toward the rotor IF there's room</TD></TR></TABLE>
Yes that's what I thought, so I pushed it back 'away' from the rotor. So you are saying I should push it back towards the rotor?
DAN
DAN
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DannyDeuce »</TD></TR><TR><TD CLASS="quote">Yes that's what I thought, so I pushed it back 'away' from the rotor. So you are saying I should push it back towards the rotor?
DAN</TD></TR></TABLE>
yeah.. if you push it towards the lower arm it's more likely to hit moving suspension parts. pull it as close to the rotor as possible then drive it around to check OR.. I cut mine off and no more rattling
yeah.. if you push it towards the lower arm it's more likely to hit moving suspension parts. pull it as close to the rotor as possible then drive it around to check OR.. I cut mine off and no more rattling</TD></TR></TABLE>
Thanks Baker, I will try that out.
DAN
DAN
integra15
Mar 15, 2007 08:36 AM
