SMALL RADIATOR OR BIG???
Old Nov 14, 2006 | 08:13 PM
blakacintegra's Avatar
Default SMALL RADIATOR OR BIG???
MY FRIEND HAS A 93 CIVIC COUPE WITH A GSR SWAP AND HE HAS THE SMALL RADIATOR IN HIS CAR AND I HAVE A 94 INTEGRA GSR WITH THE STOCK BIG RADIATOR AND IM PUTTING A TURBO KIT ON SOON SO I WAS WONDERING IF FIRST OF ALL WOULD WE BE ABLE TO TRADE AND THEY BOTH BOLT RIGHT ON AND IF SO SHOULD I TRADE HIM TO MAKE ROOM FOR THE TURBO EVEN IF I DONT THINK I NEED TO..IS IT WORTH IT? IT SEEMS LIKE IT WOULD BE IF IT DOESNT MAKE A DIFFERENCE JUST BECAUSE IT MAKES SO MUCH MORE ROOM AND IT LOOKS ALOT BETTER TO ME..SOMEONE PLEASE HELP BECAUSE HE SAID WE CAN DO IT TOMARO IF I FIND OUT IT BOLTS RIGHT ON. THANKS
Old Nov 14, 2006 | 09:22 PM
SOMEONE
Old Nov 14, 2006 | 09:36 PM
AwOrKiNpRoGrEsS23's Avatar
Default Re: (blakacintegra)
ok:
1.) no need to yell in all capitals....you'll get flamed for that so i'm just warnin you now.
2.) it all depends on your personal preference, if you don't need the space then it shouldn't make a difference. although if it's a space thing then you can run the civic radiator but you might have to make or move your mount to fit it on there. i've seen it done a bunch but never checked to see how it's mounted. maybe drop by the civic forums and see what they say.
3.) if your looking at a difference on cooling temps then i wouldn't worry about that, these cars are supposed to run so cool that having a smaller radiator would probably make no difference in cooling the engine. someone correct me if i'm wrong. mainly it would be for space and aesthetics.
Old Nov 14, 2006 | 09:43 PM
5 Speed AP2's Avatar
Default Re: (AwOrKiNpRoGrEsS23)
I initially wanted a smaller rad in my dc, but that was for 1) to make room for a bigger manifold and 2)it does look a little cleaner.
But as mentioned, its personal preference.
As far as your question about fitment, yes. It'll fit.
In any case nothing a little common sense can't fix. No hacking, welding, etc tc necessary.
Old Nov 14, 2006 | 10:08 PM
Sumslapper's Avatar
Year 3030
Default Re: (5 Speed AP2)
If you were staying N/A then it would be fine. But if you plan on boosting the gsr your really going to be pushing the civic radiator. for the best of both worlds, get a half size full aluminum radiator. it would be very efficiant and look nice and small.
Old Nov 14, 2006 | 11:02 PM
no2unenolife's Avatar
i was turbo and i used a delsol vtec dual core radiator and it worked well
Old Nov 14, 2006 | 11:52 PM
where can i get a half sized all aluminum
Old Nov 15, 2006 | 09:53 AM
yee SERIOUS's Avatar
i ran a civic automatic radiator while i had my turbo setup in. and my old DC radiator went to my cousin with a gsr EG. so hopefully you can get an idea from that.
my gsr radiator didn't "bolt" in. we had to use some zipties, but whatever holds it up! haha
you can get a an aluminum one from any HT sponser. just give them a PM.
https://honda-tech.com/zeroforum/45
Old Nov 15, 2006 | 10:05 AM
Sumslapper's Avatar
Year 3030
Default Re: (undercoverdc2)
H-T sponsors, ebay, radiatorbarn, local ricer shops
TOO MUCH TORQUE
Apr 4, 2011 05:10 PM
ohmygsr
May 27, 2007 07:45 PM
TRM04
Jan 6, 2003 11:29 AM
