CP pistons + stock rods?
Old Nov 14, 2006 | 07:08 PM
GripDriverEF's Avatar
Default CP pistons + stock rods?
Stock Drag kit, stock first-gen B16A. Two pistons failed, now time to rebuild. On a budget, as always. Will aftermarket pistons work on stock rods? Are there any issues with this combo? Gotta get this damn car back up and running. Thanks.
Old Nov 14, 2006 | 07:10 PM
slodel's Avatar
Default Re: CP pistons + stock rods? (GripDriverEF)
if its the only option go for it
ARP rod bolts and head studs
Old Nov 14, 2006 | 07:13 PM
jdm_vtec's Avatar
Default Re: CP pistons + stock rods? (slodel)
how much boost were you running? how many miles? just wondering because i'm currently doing a stock bottom end setup
Old Nov 14, 2006 | 07:15 PM
jdm_vtec's Avatar
Default Re: CP pistons + stock rods? (jdm_vtec)
btw, to answer your question, yes stock rods will work with forged pistons. I would suggest changing the rods with a set of H-beam rods.. they are only 225 at tuner toys
6.5psi and probably about 70-80k on the motor. This was bound to happen. Thanks for the info.
Old Nov 14, 2006 | 07:18 PM
jdm_vtec's Avatar
Do you know exactly what happened? I've been reading countless setups listed on here with people running 10psi on the stock B16 with no problems.
Old Nov 14, 2006 | 07:27 PM
This is what I read also, but then again I'm running the fmu still and no tuning. I've been having overheating issues, and after a hard night at the track my car decided to billow bluish smoke. Felt like I was running on 3 cylinders. Turns out it was two.
Old Nov 14, 2006 | 07:36 PM
jdm_vtec's Avatar
I hate to say it but there is your problem, the overheating issue melted your pistons. I'm guessing you checked oil level and kept coolant in the radiator.
Change your thermostat, water pump and oil pump just to be safe while your at it.
btw, sorry to hear about that
Old Nov 14, 2006 | 07:38 PM
SpdFrk's Avatar
Stock rods are press fit, forged have floating pins. They will not work unless u get your stock rods machined out.
IMHO its not worth it, just save up and get yourself some eagles.
Old Nov 14, 2006 | 07:42 PM
jdm_vtec's Avatar
Default Re: CP pistons + stock rods? (SpdFrk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpdFrk &raquo;</TD></TR><TR><TD CLASS="quote">Stock rods are press fit, forged have floating pins. They will not work unless u get your stock rods machined out.
IMHO its not worth it, just save up and get yourself some eagles. </TD></TR></TABLE>
I did not know that, sorry for the misleading response. I agree, if you have it apart why not replace the rods while you're at it?
Old Nov 14, 2006 | 07:45 PM
SpdFrk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GripDriverEF &raquo;</TD></TR><TR><TD CLASS="quote">This is what I read also, but then again I'm running the fmu still and no tuning. I've been having overheating issues, and after a hard night at the track my car decided to billow bluish smoke. Felt like I was running on 3 cylinders. Turns out it was two. </TD></TR></TABLE>
Get rid of that fmu and buy some sort of engine management system like crome, uderdata, aem...etc. Also r u stll using the inline pump that came with the drag kit or did u switch to a intank?
Old Nov 14, 2006 | 07:54 PM
Intank pump, so thats a negative on the pistons huh... well, it'll be better in the long run. When I bought the pistons, I was told they wouldn't work. He never got into detail, but I wasn't sure myself (kinda figuring he was just trying to up-sell me). So it's not a straight foward task? That's a bummer.
Ericbalanzar
Feb 11, 2015 05:14 PM
Project_SOHC_EX
Dec 19, 2009 11:58 AM
b16a4
Apr 2, 2008 08:51 AM
Mr. Vapor
Aug 31, 2005 12:20 PM
RACING INTEGRATION
Jun 2, 2005 12:22 PM
