Fuel Sending Unit -removal help
Old Nov 14, 2006 | 06:37 PM
FrankT's Avatar
Default Fuel Sending Unit -removal help
Hello,
Great info on this forum.
Have a 1989 DX Hatchback d15b2 w/ 210k
I need to change the fuel sending unit.
The fuel gauge reads empty connected normaly and it will read full if I ground one of the two wires.
But have no idea how to remove it from the tank.
Does it unscrew?
If so, how?
There are two sets of tabs that I can see on the tank after I remove the cover.
Thanks for your input
Thank you.
Modified by FrankT at 9:53 PM 11/14/2006
Old Nov 14, 2006 | 06:40 PM
zccr-xsi's Avatar
u got to unscrew that cover unclip the harness.then u have to take a screw driver and tap the tap lose.it should show u how to open it in the helms
Old Nov 14, 2006 | 07:12 PM
FrankT's Avatar
Default Re: (zccr-xsi)
Thanks for the help.
Seems like you bend the tabs up and tap on the unit to unscrew it from the tank.
I'm winging this one with no HELMS...
Old Nov 14, 2006 | 07:21 PM
zccr-xsi's Avatar
hum?if u go over to zcr they got crx shopmanual it will be better then hlems?
Old Nov 14, 2006 | 08:38 PM
hondavet's Avatar
Default Re: Fuel Sending Unit -removal help (FrankT)
Are you sure the sending unit is bad? It's common for the gauges to fail on those Civics.
Old Nov 15, 2006 | 06:29 AM
FrankT's Avatar
Default Re: Fuel Sending Unit -removal help (hondavet)
YES it's bad, I tested the gauge and its good.
I was testing the fuel pump and jumped the wrong wires.
12v to the sending unit for just a second killed it...
I will try to revove it after my coffee this morning.
Thanks everyone for helping this Honda NOOB
Old Nov 15, 2006 | 06:51 AM
FrankT's Avatar
Default Fancy pants fuel sender wrench
Old Nov 15, 2006 | 07:10 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: Fancy pants fuel sender wrench (FrankT)
You can usually use a hammer and a dull chisel to
gently tap the retaining ring loose/off..
Be patient and work from side to side or it will try to wedge..
Also a good idea to hit the top of the tank with compressed air
to get all the dirt out of the area so it doesn't end up in the tank..
Welcome to Honda-tech...
Old Nov 15, 2006 | 08:32 AM
FrankT's Avatar
Default Re: Fancy pants fuel sender wrench (88DXCRX)
Thanks 88dxcx, great advice.
Anyway got it out, and took out my fancy electrical tools (ohm meter & sodering iron) and did a repair. not too pretty but it works!!!!!
StrikerX
15
Jan 10, 2022 05:45 PM
Diode
Aug 9, 2012 08:09 PM
BIGef
Nov 7, 2011 06:15 AM
staticCRX
Dec 11, 2004 10:56 AM
wannakno
Jun 27, 2003 08:20 AM
