Loud, high pitch noise when reversing! HELP!!
Old Nov 14, 2006 | 06:28 PM
silentbeatz's Avatar
Default Loud, high pitch noise when reversing! HELP!!
I just finished a swap on my 98 civic. Now the car is running great, but when I am reversing, the car lets out a loud, high pitched squeal. I dont know what could be causing this, but it only happens in reverse.
The power steering is disconnected because I'm waiting for a bracket/pump to come in. Could the noise be caused by the car previously having PS?
Also, will having PS disconnected damage the rack and pinion or PS lines?
Old Nov 14, 2006 | 06:31 PM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
Default Re: Loud, high pitch noise when reversing! HELP!! (silentbeatz)
You mean like an RC car noise [sorta]? Cuz, umm... That's normal.
I assume you mean like a belt squealing or something? Something real high pitched and annoying?
Old Nov 14, 2006 | 06:35 PM
It's pretty much like a belt squealing but worst. I think it can be heard from 2 blocks away.
Old Nov 14, 2006 | 07:04 PM
Default Re: (silentbeatz)
Old Nov 14, 2006 | 07:23 PM
ATEJ8FTW's Avatar
Default Re: Loud, high pitch noise when reversing! HELP!! (Hatchy-Ownzjo0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatchy-Ownzjo0 &raquo;</TD></TR><TR><TD CLASS="quote">You mean like an RC car noise [sorta]? Cuz, umm... That's normal.
I assume you mean like a belt squealing or something? Something real high pitched and annoying?</TD></TR></TABLE>
Every honda i've been into has that rc car noise.
Old Nov 14, 2006 | 07:44 PM
EG2Driver's Avatar
Default Re: Loud, high pitch noise when reversing! HELP!! (ATEJ8FTW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ATEJ8FTW &raquo;</TD></TR><TR><TD CLASS="quote">Every honda i've been into has that rc car noise.</TD></TR></TABLE>
i've been wondering what that noise was. What is it caused by?
Old Nov 14, 2006 | 07:50 PM
stock_honda_coupe's Avatar
Default Re: Loud, high pitch noise when reversing! HELP!! (DeadEnd9009)
Its how the gears in reverse mesh together. they are desinged differently than all the forward gears. thats why they grind easier too.
About the noise, Does it change at all when you turn?
Old Nov 14, 2006 | 08:00 PM
EG2Driver's Avatar
Default Re: Loud, high pitch noise when reversing! HELP!! (stock_honda_coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stock_honda_coupe &raquo;</TD></TR><TR><TD CLASS="quote">Its how the gears in reverse mesh together. they are desinged differently than all the forward gears. thats why they grind easier too. </TD></TR></TABLE>
Yea Reverse does not have syncros, thats why if ur moving it'll grind. They're also straight gears, unlike the other gears...so i guess thats what made that noise. Thanks!
Old Nov 14, 2006 | 08:05 PM
jpnucrx's Avatar
The reason your reverse gears let out that high pitched noise is the way they are cut. Regular gears are straight cut, where as reverse is Helical cut. Helical cut gears are stronger than straight cut gears. Thats why all drag cars have them and they are loud as hell, thats why they dont put them in DD's.
Old Nov 14, 2006 | 08:08 PM
jpnucrx's Avatar
Default Re: Loud, high pitch noise when reversing! HELP!! (jpnucrx)
Oh...and reverse should never grind, because you are supposed to put the shifter into first gear, then into reverse. It doesnt grind because it doesnt have sychros. You have to stop the tranny spinning forward in order to put in reverse.
Old Nov 14, 2006 | 08:25 PM
my car never made the noise before the swap though. when i turn the wheel the noise get louder and screechier (if thats a word). thats why i was wondering if it's from the power steering being disconnected.
Old Nov 14, 2006 | 08:27 PM
IT'S ME DAVID's Avatar
NooB
maybe u got an lsd.lsd usually make weird noises.
Old Nov 14, 2006 | 08:37 PM
no lsd. i did the clutch when the motor was out
Old Nov 14, 2006 | 08:45 PM
punoy69's Avatar
**EDIT** Woops I didn't read your 2nd to last post, sorry lol. Delete this. **EDIT**
Old Nov 15, 2006 | 06:53 AM
Default Re: (punoy69)
Are your belts tight?
Syndacate
Dec 2, 2007 05:26 AM
Silvteg95
Aug 1, 2005 11:28 AM
coupe99vtec
12
Mar 1, 2005 11:20 AM
NoLipRacen
Nov 4, 2003 04:50 PM
el arbi
15
May 18, 2003 09:06 AM
