water leaks...
Old Nov 14, 2006 | 05:23 PM
gator88's Avatar
Default water leaks...
after reading on here about people finding water leaks around their crx, i have come across the same problem. i have learned from reading it is probably my rear sprayer nozzle causing the leaks. this is why i believe so...it doesnt work as if the hose is off of it, my dome light doesnt work, and the water drips on both sides from where the shocks for the hatch attach at. i have heard all these are signs of it being cause by that damned little hose falling off. my question is, how do i get that hose back on? i dont know how to gain access to it. i honestly have no idea where to begin. also, if i get this hose back on the nozzle, will these leaks go away do you think? it is what i consider a substantial amount of water, not enough to drench both sides, but to leave four long water trails down the front of the cargo cover. Any and all help greatly appreciated!! TIA!
Old Nov 14, 2006 | 05:40 PM
gator88's Avatar
Default Re: water leaks... (gator88)
bump?
Old Nov 14, 2006 | 06:42 PM
zccr-xsi's Avatar
ever try cleaning out the drain tubes?
Old Nov 14, 2006 | 06:58 PM
cdub21's Avatar
New User
Default Re: (zccr-xsi)
that is exactly what he want to do but is looking for a directions on how to get to the tube.
not a civic but it might help
http://www.g2ic.com/forums/sho...tubes
Old Nov 15, 2006 | 02:45 AM
gator88's Avatar
Default Re: (cdub21)
anyone else?
Old Nov 15, 2006 | 04:09 AM
KickStart2323's Avatar
Default Re: (gator88)
my crx dose the same thing leaks water at the hatch shocks
also check your weather stripping any cracks in that you get water leaks
Old Nov 15, 2006 | 05:13 AM
CRX Toad's Avatar
kaboose79
Nov 22, 2016 07:43 AM
Dekorum
18
Sep 28, 2010 07:55 AM
joelmatt89
21
Apr 15, 2009 06:16 PM
mac_24_seven
Dec 29, 2008 01:27 AM
screen_name
Apr 30, 2005 05:54 PM
