The best way to clean and restore valve cover appearance
Old Nov 14, 2006 | 05:01 PM
steveo2000em1's Avatar
Default The best way to clean and restore valve cover appearance
Need some advice on what you would use to clean this.
See Here
I'm in the process of stripping off the paint and repainting. I want the DOHC VTEC and the Honda Logo to not have that crap around the outside of it.
What did you use?
TIA
Old Nov 14, 2006 | 05:03 PM
SiYouLater's Avatar
Default Re: The best way to clean and restore valve cover appearance (steveo2000em1)
Sand paper.
Old Nov 14, 2006 | 05:23 PM
Si_chRis's Avatar
Default Re: The best way to clean and restore valve cover appearance (99FBPSi)
Aircraft paint remover will strip everything to bare metal leaving it for your to paint it yourself or u can leave it bare metal
Old Nov 14, 2006 | 05:26 PM
I'm using aircraft paint remover to strip the paint.
Paint is not the problem.
If you look at the pic where the DOHC and VTEC are located you'll notice around the edges it needs to be cleaned up.
I started using some steel wool and it's working somewhat but I was just wondering what others have had luck with.
Old Nov 14, 2006 | 05:52 PM
Si_chRis's Avatar
Default Re: (steveo2000em1)
it looks like its corroded. the only thing u can do is maybe sand it down a little?
Old Nov 14, 2006 | 05:54 PM
Thizzed Out's Avatar
Default Re: (EM1_ChRiS)
um maybe they can help u
https://honda-tech.com/zerothread?id=1799703
Old Nov 14, 2006 | 06:19 PM
T-RO's Avatar
just use sandpaper
Old Nov 14, 2006 | 06:20 PM
Frozen E's Avatar
H-T White Ops
wooden block with some 400 grit sandpaper wrapped around it. Keeps everything nice and square. Just sand the letters.
Old Nov 15, 2006 | 03:50 AM
Default Re: (IslandSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IslandSi &raquo;</TD></TR><TR><TD CLASS="quote">wooden block with some 400 grit sandpaper wrapped around it. Keeps everything nice and square. Just sand the letters.</TD></TR></TABLE>
Going to try it...Thanks everybody
Old Nov 15, 2006 | 05:34 AM
Vindicator9000's Avatar
318 Curves, 11 miles
dremel with wire wheel and polishing disc.
Old Nov 15, 2006 | 05:56 AM
Default Re: (Vindicator9000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vindicator9000 &raquo;</TD></TR><TR><TD CLASS="quote">dremel with wire wheel and polishing disc.</TD></TR></TABLE>
Do you need a liquid polish too?
Old Nov 15, 2006 | 06:06 AM
teal_dx's Avatar
Here's a write-up with pics on how to polish a valve cover:
http://civic-eg.com/viewtopic.php?t=180
Old Nov 15, 2006 | 06:10 AM
Default Re: (teal_dx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teal_dx &raquo;</TD></TR><TR><TD CLASS="quote">Here's a write-up with pics on how to polish a valve cover:
http://civic-eg.com/viewtopic.php?t=180</TD></TR></TABLE>
That link is just what I needed. Thanks
Old Nov 15, 2006 | 06:34 AM
RaYnE's Avatar
i sandblasted mine, then polished the lettering. sandblasting works well.
Old Nov 15, 2006 | 06:42 AM
To get the paint off the easiest way was to just spray down the valve cover with Aircraft paint remover. I let it sit for 30 min after spraying it and all you have to do is spray it off with a hose. Very easy. Just don't get the stuff on your bare hands.
Old Nov 15, 2006 | 12:30 PM
HondaJack's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steveo2000em1 &raquo;</TD></TR><TR><TD CLASS="quote">To get the paint off the easiest way was to just spray down the valve cover with Aircraft paint remover. I let it sit for 30 min after spraying it and all you have to do is spray it off with a hose. Very easy. Just don't get the stuff on your bare hands.</TD></TR></TABLE>
Where can I get that Aircraft Paint remover?
Old Nov 15, 2006 | 12:34 PM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
Default Re: (HondaJack)
If you use aircraft stripper, make sure you do it in the open with lots of air flow, and wear a mask. I had to go to the hospital after stripping the paint off of my valve cover because I had an alergic reaction to the aircraft stripper and turned into a giant hive.
Old Nov 15, 2006 | 01:21 PM
white ex's Avatar
Default Re: (Hatchy-Ownzjo0)
Exactly what i did and it came out perfect
Old Nov 15, 2006 | 03:25 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaJack &raquo;</TD></TR><TR><TD CLASS="quote">
Where can I get that Aircraft Paint remover?</TD></TR></TABLE>
I got it at Autozone. It costs about $6.
Old Nov 15, 2006 | 03:27 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatchy-Ownzjo0 &raquo;</TD></TR><TR><TD CLASS="quote">I had to go to the hospital after stripping the paint off of my valve cover because I had an alergic reaction to the aircraft stripper and turned into a giant hive. </TD></TR></TABLE>
Did you use it in your garage?
I used it outside and just sprayed it on the valve cover until it was completely covered and went inside for 30 minutes. How long did it take for you to get sick?
Old Nov 15, 2006 | 04:58 PM
H-T Poker champion
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steveo2000em1 &raquo;</TD></TR><TR><TD CLASS="quote">Did you use it in your garage?
I used it outside and just sprayed it on the valve cover until it was completely covered and went inside for 30 minutes. How long did it take for you to get sick?</TD></TR></TABLE>
I did it out on the sidewalk.. I had was scrubbing the valve cover for a good 5 - 10 minutes trying to get every little bit of paint off. My face was pretty much in close proximity to the aircraft stripper the whole time. You should be fine.
Old Nov 15, 2006 | 06:36 PM
vlc92189's Avatar
its 5 bucks a can at autozone... and i put some cardboard down.. sprayed it.. and let it sit for 10 mis.. took a trash can then sprayed the vc off with the hose and it was all stripped
mannydhanju
Jan 22, 2009 08:36 AM
wrinkles
Mar 19, 2006 03:33 PM
uses0ap
Mar 15, 2006 07:37 PM
mountaindewguy
Mar 9, 2005 06:37 PM
Honda97
10
Nov 14, 2004 06:31 PM
