question about a cast manifold I just bought....
Old Nov 14, 2006 | 03:55 PM
integraracing91's Avatar
Default question about a cast manifold I just bought....
http://cgi.ebay.com/ebaymotors...ZWDVW
Just bought one of those manifolds for a budget build and noticed the 38mm wastegate hole is a little smaller then the actual wastegate.
Will this effect boost creep?
Should I go to a machine shop and get it bored out a little bit?
Thanks for any help
Old Nov 15, 2006 | 03:23 AM
Default Re: question about a cast manifold I just bought.... (integraracing91)
bump
Old Nov 15, 2006 | 04:27 AM
redzcstandardhatch's Avatar
something different
just port it out a bit with a die grinder
Old Nov 15, 2006 | 05:09 AM
akira712's Avatar
i made 330/260 on that mani, used a 35mm to make 300/255 and had NO boost creep or spiking issues.
Only issue i had with the mani is the wg will hit the head (for vtec heads, ok for non vtec) and the gap between the #2 & #3 runners is so small theres barely any room for the dip stick
TB123
Feb 29, 2008 08:08 PM
greekspeed
Jan 7, 2004 02:59 PM
B00stedCoupe
Nov 11, 2003 04:15 PM
MRSI00
Jan 12, 2003 09:13 PM
