Injector Resistor Box?
I've searched and only found threads about buying and selling these boxes.
Will any '88-'91 Civic injector resistor box work for DSM 450s or any high impedance, Peak and Hold injector?
ohm the injectors, if they are 2-3 ohms you need an 88-91 civic resistor box. if they ohm 12-12 ohms you dont.
but if they are dsm's, you will need a resistor box. and yes a 88-91 si box will work. ps, i am running RC 1200's p&h with an ef resistor box.
try searching again, and this time pick the turbo forum, that should get rid of all the classifieds for ya. I don't know the answer, i feel like there are others that work though.
the 10w 10ohm resistors i was gonna use were lke 1/4" square and like 1 1/4 long and i dont think they would look right soldered in liine to my injectors. and i have my resistorbox hidden, so for clenliness,i think they are better.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EX-T »</TD></TR><TR><TD CLASS="quote">The ones I have are cylindrical and pretty small. Nothin' a little shrink wrap can't fix!</TD></TR></TABLE>
The resistor boxes have a heat sink.Small resistors with shrink wrap sounds like the wrong direction.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR »</TD></TR><TR><TD CLASS="quote">
The resistor boxes have a heat sink.Small resistors with shrink wrap sounds like the wrong direction.</TD></TR></TABLE>
Why is that the wrong direction? 10ohm resistors aren't going to dissipate that much heat. The reason the resistor boxes have a heat sink is probably b/c the resistors are in close proximity, meaning more heat.
