Steering colum/ignition switch replacement.
Old Nov 14, 2006 | 02:15 PM
Wayne_Curr's Avatar
Default Steering colum/ignition switch replacement.
So i've had a bent steering column from thieves for a long time. I have the replacement (I believe its OBD2 but I can just swap the wiring right?) but I want to use my existing ignition switch on the new column. Is it possible to just swap it over or do I need to get the new column's ignition re-keyed? Searched around, this doesn't seem to be a common thing to do...
TIA
Old Nov 15, 2006 | 12:51 PM
Perfectionist's Avatar
Default Re: Steering colum/ignition switch replacement. (Wayne_Curr)
The keyed part of the switch is connected to the electrical part by two, maybe three screws. You should be able to swap key cylinders withaout any problem.
BrayzieEF9
May 4, 2010 07:30 PM
Itzmy91Teg
Jun 29, 2006 08:24 PM
carnifex
Mar 3, 2005 01:26 PM
92lxguy
Oct 4, 2004 07:14 PM
wolfen
Acura TL, RL & ZDX
Jul 17, 2004 06:16 PM
