water leak - specifics needed *pics*
Old Nov 14, 2006 | 01:52 PM
ethereal2pt2's Avatar
Default Water Leak - Searched; specifics needed. *pics*
okay before you get the urge to call me a noob and use the search button. i already did. the water is located in some weird spots. it's been raining hard for a week now and i had a car cover on and when i went in to check there was about an inch and a half of water collected on the floormat. luckily, i got that water vac'd out. water leaked again today after the rain. now from what i hear it's either bad/ripped weatherstripping around the trunk or bad/ripped/clogged drain tube in the sunroof. i checked both my trunk and my door seals and they seem to have held up pretty good. now im trying to locate the drain tube and it seems like it would be located in the passenger side a pillar? correct me if im wrong. my questions are..
1) if the trunk is leaking, is it possible that it can leak water into the passenger floormats?
2) if it's the drain tube, is it located in the passenger side a pillar?
3) if it's in the a pillar, how do i reach it? do i pry open the panel?
here's the pics.
sorry if some of them are dark.
passenger's side - c pillar
driver's side - window
ceiling - above rear seats/rear window
trunk - below weatherstrip
stupid question.
this is for something like a bike rack right? nothing to do with draining?
those pictures were from about 10 mins ago. this is how i found it a few days back. when i realized there a was a leak. not much common sense needed..
got it vac'd
oh yeah sorry to sidetrack but anyone have any thoughts on this?
my friend's was made out of rubber? mine does not look like rubber. it's chipping now. any takers?
any thoughts/input/advice/past experiences would be awesome.
i apologize for the billion questions.
thanks guys.
- mike
Modified by _BB6 at 3:24 PM 11/14/2006
Modified by _BB6 at 3:30 PM 11/14/2006
Modified by _BB6 at 3:31 PM 11/14/2006
Old Nov 14, 2006 | 02:29 PM
Jagan'92's Avatar
Default Re: Water Leak - Searched; specifics needed. *pics* (_BB6)
there's a grommet behind the kick panel that leads into the fender. I would check that, it has leaked on me before, but water collected in the front passenger floorboard. I think one sunroof tube drains into that fender too.
https://honda-tech.com/zerothread?id=1629096
Old Nov 14, 2006 | 02:35 PM
Default Re: Water Leak - Searched; specifics needed. *pics* (Jagan'92)
hmm.
where's the kick panel located?
they didn't seem to have answered that question in the thread either.
thanks.
Old Nov 14, 2006 | 02:49 PM
typeS's Avatar
Check the sunroof too. I've seen water in the floorboard from that. Maybe clogged sunroof drains?
Old Nov 14, 2006 | 03:31 PM
Default Re: Water Leak - Searched; specifics needed. *pics* (typeS)
im guessing you haven't read my post since i already said it's probably from the sunroof drain tubes. im asking how do i access it so i can check them out? oh and any other way water could get in thru the trunk area? my weatherstripping seem to be holding up.
Old Nov 14, 2006 | 03:37 PM
mlow634's Avatar
I have a minor water leak and am looking for the sun roof drain or whatever as well. As for the weather stripping right under the window, I have the same thing happening to my 97 prelude. We tried tinkering with them to take them off so I could buy replacements, but we couldnt get them off. I remember reading a thread a whiles back on a similar topic. Also, my weather stripping is way worse than yours, probably 30-40% covered with original black paint or whatever it is.
Old Nov 14, 2006 | 06:09 PM
Jagan'92's Avatar
the kick panel is the interior plastic piece, at the floor, between the door and the firewall, like what the fuse box is under on the driver side.
there's a grommet for a wire bundle that goes from the dash, through the fender, and into the door.
Old Nov 14, 2006 | 06:21 PM
hella_usdm's Avatar
my guess is the sunroof drain tubes are plugged with ****.
Old Nov 14, 2006 | 07:29 PM
once again ppl are missing the point. this is exactly why all the other threads didn't help. yes i figured it was the drain tube from the sunroof. i believe i've already established it. im not tryna be rude or anything but thank you captain obvious for pointing out that it's the drain tubes when it's been covered at least 3 times already. back to the point. i just checked and my rear seats are totally soaked wet. any thoughts on how water could get there? someone from the other thread said there was 4 drain tubes? i thought there were only 2? but if it's 4 then wouldn't the rear ones run down the c pillars? if that's so, could that be a viable source for the water?
just to add one more thing.
i desperately ask of you guys to refrain from restating what has been said and stating the obvious. this is partly why ppl get flamed for posting the same topics. because ppl just restate what the prev. guy says and nothing gets solved. then when other ppl need help with the same thing they are left but with one choice to repost the topic. but seriously thank you to all the other ppl who've been a great help. i really appreciate it.
Modified by _BB6 at 8:55 PM 11/14/2006
Old Nov 14, 2006 | 07:32 PM
esedulerp5tenin's Avatar
Default Re: (hella_usdm)
do what my pops and i did when i had a similar problem: sit inside the car while someone sprays a hose over your entire car. see if you can find the leak.
Old Nov 14, 2006 | 07:40 PM
97 Sleeper's Avatar
Default Re: (esedulerp5tenin)
^^^ that sounds like a good idea to see where its leaking from...thats crazy thou never seen so much water in a car...goodluck man
Old Nov 14, 2006 | 07:57 PM
good idea.
thanks i'll try that tmro.
im sorry im super tired today but uhh
im looking for the kick panel to get access to the drain tube correct?
ooh flame suit on..
Old Nov 14, 2006 | 07:59 PM
prelude1897's Avatar
Default Re: (97 Sleeper)
holy crap man that's alot of water on your floor board....Pop your trunk and look at your spare tire to see how much water is sitting back there. If you have that much just inside your car, you must have damn near a pond in hte trunk itself
Old Nov 14, 2006 | 08:12 PM
Default Re: (prelude1897)
yeah i forgot to mention the trunk. i popped open the trunk and everything was moist. i take out the spare tire compartment and bam my tire is like swimmin in water. i read your other post about the drain plugs [thanks] so i popped one of them suckers out and it started draining.. on my shoe.. haha damn but least i got it out. my weatherstripping doesn't seem to be bad around the trunk. any other ways it could have gotten into my trunk? man my car is one high maintenance queen.. first the motor now this. thank guys.
Old Nov 15, 2006 | 08:28 AM
Jagan'92's Avatar
Default Re: (_BB6)
you responded in your rant to me... that makes me sad.
based on the trunk full of water, and looking at the pictures closer, that looks like water is running down from the roof. that grommet I mentioned would only account for the floor getting soaked. here's a link to the drain tubes but I don't remember where the tube ends (only 2 are shown). You may need to run the water on your car to find the tubes, and I'd guess the one you're looking for is the rear passenger.
http://slhondaparts.com/browse...+ROOF
the only other thing I can think of for the trunk leak is the taillights may not be sealed.
Old Nov 15, 2006 | 02:59 PM
Default Re: (Jagan'92)
oh my bad. i didn't mean to direct that at you. i just have a habit of clicking on the last reply button. you've been one of the few who's actually helped me. thanks man.
Old Nov 15, 2006 | 03:41 PM
britishdude's Avatar
There are 2 x drain tubes, one on the front passenger side runs down the pillar and drains out at rear of wheelarch, the rear drain tube runs down the drivers side rear pillar and behind the lining of the trunk and exits the car under the trunk. You have to remove the trunk lining to get to it making sure it's not blocked, there are drain valves on the ends of the tubes make sure it's all clear.
http://www.hondaautomotivepart...+ROOF
Old Nov 15, 2006 | 04:11 PM
VtecFreePrelude's Avatar
britishdude beat me to it
they should be behind the c pillar covers and drain in the wheel well
Old Nov 15, 2006 | 04:40 PM
Default Re: (VtecFreePrelude)
thanks guys. that really cleared up a ton. i'll check that out tmro. couldn't test out the hose thing today. my hose has a big oh tear. too big for patching up. why does everything seem like they're breakdowning these days. what luck. now for the trunk. aside from what jagan mentioned, does anyone else have any ideas where the water could be coming from? thanks guys.
Old Nov 15, 2006 | 06:27 PM
Default Re: (_BB6)
check the seals around the tail lights
Creature1
Honda Civic (2001 - 2005)
May 5, 2014 10:13 AM
mcd7
Jan 21, 2012 11:33 AM
joelmatt89
21
Apr 15, 2009 06:16 PM
OBDII Integra
Aug 27, 2008 09:11 AM
swt_666
Dec 23, 2006 08:36 PM
