can a obd0 b16 ecu be used on a d15b>?
Old Nov 14, 2006 | 01:42 PM
4dOoR-Ex's Avatar
Default can a obd0 b16 ecu be used on a d15b>?
i made thread b4 but i didnt get any info.....THe StorY.....i have a 91 civic ex (4d00r) thats obd0..i fVCkT up the motor...so i swapT in a d15b..i have all the ****.2 make it obd1 BUt i said FVCk it NO time 2 wire **** UP...so i used my manifold and dizzy(first swap ever done in a day an a half by my self))...PLUS wen i got the swap the manifold was missing a sensor..the car runs good...no CEL lights..now i got my hands on a obd0 pr3 ecu....my question is can i run the ecu and open vtec.i plugd the ecu in my car and that **** starts up and all.. idle is a lil off but nothing i cant FIX..soo wat are the pros and cons..(( not chiping or remaping ****...) thanx.. angel...
Old Nov 14, 2006 | 03:10 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: can a obd0 b16 ecu be used on a d15b>? (4dOoR-Ex)
it should throw a CEL for second O2 and knock sensor unless you actually adapt these two sensors to your setup
Old Nov 14, 2006 | 06:16 PM
4dOoR-Ex's Avatar
its a 95 d15b wired obd0..still using my 1 o2 sensor..i did take maybe like 2 plugs from the back of my d16a and used them on the d15..
Eaglekper0046
Nov 20, 2007 11:58 AM
civickid03
Jul 13, 2006 01:29 PM
absolut b18
Aug 26, 2003 02:27 PM
gokooljapan
Mar 14, 2002 06:13 PM
