NEED HELP- Valve cover Bolts snapped!
I recently took my Valve Cover off to paint it, removal went fine. When I put the Valve Cover back on I began to tighten the nuts down to 9ft lbs. They never made it, they either snapped or the whole bolt would just rotate with the nut. What do I do? I mean Im not sure what to do since its an aluminum head. Pls help.
Remove the valve cover and buy new studs to replace the ones you snapped.
I never torque these bolts because they will snap. Use a 1/4" ratched and snug them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flipwhip »</TD></TR><TR><TD CLASS="quote">any idea on prices? Thanks alot guys.</TD></TR></TABLE>
Not sure. I might have one from a spare Civic engine if they are too expensive from the dealer.
Just tape a pic of the one on your car and send it to me. I will compare it to the one I have.
lol kinda off the subject but one day i was workin on my cams and i lost the lil seal/ washer or figure 12 on the diagram....... know where i can replace those?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a »</TD></TR><TR><TD CLASS="quote">
I highly doubt you stripped where it connects to the cam cap/head.</TD></TR></TABLE>
is this picture from the helms manual???
No, exploded parts diagram from http://www.slhondaparts.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a »</TD></TR><TR><TD CLASS="quote">No, exploded parts diagram from http://www.slhondaparts.com</TD></TR></TABLE>
thanks a lot thats a very helpful site
http://www.hondapartsdeals.com ftw
there is no need to go more than snug with these though....there is very little force on the valve cover....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flipwhip »</TD></TR><TR><TD CLASS="quote">When I screw them into the head do I have to tighten it to a certain Ft. LBS?</TD></TR></TABLE>
I would just tighten them until they're snug, then maybe an extra 1/4 turn. There is no pressure on the VC, you're just tightening them to seal the VC gasket.
